MikeMN
Flight distance : 677031 ft
Hi All,
This weekend I had my Air 2s folded up in a backpack with one of those brackets to secure the props, etc. When I opened up the backpack I realized the drone was powered on by something leaning against the backpack, and the battery was almost fully drained (started with full charge). Not only was the battery very hot, but the underside of the drone was too hot to touch.
After I let everything cool off I recharched the battery to about 60%, but when unplugging it the lights stayed on, not just flashing status then turning off like usual. I let it sit for about an hour, then it started behaving normally. I finished the charge and a test flight seemed to go fine.
Do I need to be worried that I damaged either the battery or the drone? Is there a way to run any diagnostics on the battery to confirm? Might be time for a hard-sided case...
Thanks in advance,
Mike
