PGYTECH - DJI Mini 3 Pro Filters
5860 28 2022-6-2
Mini-G
Flight distance : 673862 ft
Hi all,
I've been waiting for filters to be release and noticed PGYTECH have put the following up on their website.
What's interesting is that they're the first site to release the weight information for each filter or filter set.
The ND/PL, ND and CPL filters will come in at 5.7 grams each. Then the UV filter at 3.3 grams.
So it seems using a filter will push it over the 249 gram.
Does anyone know how this plays out with sub 250 gram registration?
Has anyone received their offical DJI Mini 3 Pro filters and weighed them?
Thanks all!
ND/PL set
ND/PL set
ND set
ND set
CPL
CPL
2022-6-2
DJI Stephen
Hello there Mini-G. Good day and thank you for reaching out. Since this is a 3rd party accessory ( Filters ) for your DJI Mini 3 Pro, I hope that you will get the best recommendation from our fellow DJI co pilot who uses these filters on there DJI Drone. Just a reminder that DJI does not recommend for you to your 3rd party accessory like filters on your DJI Mini 3 Pro. There is a possibility that these 3rd party accessories will be able work properly. However, since it's not tested by DJI we cannot guaranteed the safety of the said 3rd party accessories if it will work all the time with no issues and might void the warranty of your DJI Mini 3 Pro. Thank you.
2022-6-2
Wiz33
Flight distance : 35994 ft
I will likely get the 4 filters set instead of the DJI one, debating if I want the PL version but it's a bit of a hassle and is of limited use.
2022-6-2
Mini-G
DJI Stephen Posted at 6-2 20:35
Hi,
Can I please ask, how come these warnings aren’t posted when it comes to filters for DJI Air 2s or Mavic 3 models?
Thanks
2022-6-3
Mechanism
The DJI store claims 0.75g each
2022-6-3
preiffer
Remember they *replace* the existing clear filter on the front of the camera - so it's the difference between the two that you need to measure, not the actual weight of the new filter alone.
2022-6-3
szymko
Flight distance : 367165 ft
Poland
Freewell ones are 0.7g (at least this is what the manufacturer claims). I am glad I preordered these. They are probably made of polycarbonate instead of metal.
2022-6-3
Mini-G
szymko Posted at 6-3 02:12
You could be right about the material.
They’ve been posting a fair bit of production videos on their Instagram
2022-6-3
Montfrooij
Flight distance : 2560453 ft
I had some bad experience with PGY filters.
2022-6-3
Manich
Flight distance : 1975351 ft
The DJI store lists their own original brand filters, those being a set of 3 ND filters and a Wide angle filter, each of which weighs less than 1gram, so they wouldnt put the drone over the 250g limit for registration. In all honesty, I dont see any regulatory authority being so sad as to be that picky over a few grams. Its neither here nor there. I did hear someone argue that the additional weight of 3rd party filters could put undue strain on the gimbals motors, but I doubt that myself. Theyre fitted to the sensor housing, and the actual front where the filters are fitted are very close to the axis of the motor, so I wouldnt be worried about using them.  Im more concerned about the now old age question of 'Will I actually ever receive my DJI filters which Ive already paid for?' Thats the real issue here.
2022-6-6
Wiz33
Montfrooij Posted at 6-3 11:02
Like? I had problem with the initial batch of ND filters for the Original Mini but everything else that I got for my other devices. drones, works fine.
2022-6-6
nosnoop
Flight distance : 237953 ft
Manich Posted at 6-6 15:02
You said "In all honesty, I dont see any regulatory authority being so sad as to be that picky over a few grams."
Regulation is regulation.   It's not being "picky" or not.   Everything is stated in black and white.
When the threshold is 250g as in Canada between micro drone and small drone, which have totally differents set of rules here, then your drone is either a micro drone or a small drone.
And yes, the 1g could be the difference.
2022-6-6
Mini-G
I keep hearing about this wide angle filter.
Where can you see it? I’m in Australia and not sure if they’re just not listing it on the DJI Au portal.
Have you got a link?
2022-6-6
Montfrooij
Wiz33 Posted at 6-6 17:12
I had 2 variable ND filters for my P2 but returned them.
They gave a very bad color shift on bot ones.
Here is a quick example where the outer 'ring' has a blue cast.
2022-6-6
Manich
Mini-G Posted at 6-6 19:20
https://m.dji.com/uk/product/dji-mini-3-pro-nd-filters-set-16-256
I cant find the WA filter on the DJI sight, but other retailers are listing them, one example below:
https://www.heliguy.com/products/dji-mini-3-pro-wide-angle-lens
2022-6-7
Exib
Flight distance : 153760 ft
preiffer Posted at 6-3 01:49
That's a very good point and this must be taken into account, would be interesting for someone with the Mini 3 to remove the front lens and see what the weight is
2022-6-7
Mini-G
Exib Posted at 6-7 03:33
I’d love to try one out but no one has an idea of actual ETA…
2022-6-7
Manich
nosnoop Posted at 6-6 18:42
What I meant by regulatory authority, wasnt the likes of the CAA or FAA, but rather the average police officer or other such role. I mean its not like they carry scales around with them.
An example. I was flying my P4P a while back, maybe 50m off some cliffs over the sea. Someone had rang the police because they could see me doing so from their home, which was well beyond the 150m requirement. The officer pointed out that there were people walking along the clifftop path and asked me what the regulations stated as to separation from the public. I just pointed out that they werent around when I launched and began shooting the video, and that I had no real way of knowing the true distance to them and that it was a rough estimate, or a guess. he agreed with that and just asked me to be careful, which I always am, then went on his way.
2022-6-7
Wiz33
Montfrooij Posted at 6-6 22:41
Interesting, I have always sticked to just numbered ND and have not tried variable, Will keep that is mind. Did you replace them with another manufacturer and how's the result?
2022-6-7
The Saint
Flight distance : 5902228 ft
looks like the oem filters are now available.
2022-6-7
rodc27
I have a scale that measures to 0.1g, so will weigh both the original blank cover, and the DJI ND filters later and post the results.
2022-6-7
Montfrooij
Wiz33 Posted at 6-7 07:32
Well, I have one VND filter for my Nikon and it is 'ok'.
But for 2 reasons I replaced these 2 pgytech ones with fixed ND filters for my P2.
First reason is fear of another 'bad' experience.
Second reason is that it was not as handy as I anticipated.
Mainly because you still have to take them off when you stop filming (or risk bumping them into something) because the lens is facing the 'wrong' way and I don't want to have it like that for too long.
So I ended up taking the VND filter on and off all the time.
Which almost eliminated the whole idea of having a VND filter.
So I bought a 'normal' PolarPro set and a Freewell ND1000.
The last one I use a lot for motion timelapses. The standard ND filters were used only a very few times.
I hate putting them on and off. Way too flimsy. And I'm bound to lose them.
So even though the end result looks a bit better, it is not worth it most of the time for me.
2022-6-7
Wiz33
Montfrooij Posted at 6-7 12:43
   Same here for my experience on the P1/2. I use them mostly when I travel and the whole idea is that it's something you can start up and begin recording in about 10 seconds and having to fiddle with ND filters kinda defeat the purpose. Except in specific situation when you have time to setup for some unique shots. I do use them more often on my drones as most daylight shot can benefit from a lower shutter speed.
2022-6-7
rodc27
Weight of Mini 3 Pro - 248.4g
Original bare lens - 0.8g
DJI ND filter - 0.7g
So as long as other ND filters are 2.3g or lighter, M3P will still be under 250g.
2022-6-7
gnirtS
Flight distance : 5712575 ft
Those PGY filters will be mostly useless.
The Mini 3 is going to require *at least* and ND32 and likely up to ND256.
Anything lower than that isnt going to block enough light to get a slow enough shutter speed.  The f/1.7 lens is going to ensure that.
2022-6-7
Bussty
Flight distance : 320951 ft
New Zealand
Has any body seen a single ND 1000 or stronger available for the Mini 3 Pro? I can only find this pack which includes a ND 1000 but don't need the others as don't shoot video...
Freewell ND link
2022-6-7
Mini-G
rodc27 Posted at 6-7 13:26
Fantastic news!!
2022-6-7
Mini-G
gnirtS Posted at 6-7 13:44
Agreed.
I don’t know why they would bother with an ND8… unless your shooting in the afternoon but surely it would be fine without an ND filter.
2022-6-7
Wiz33
Mini-G Posted at 6-7 15:35
Agreed.
Cloudy day, early morning, late afternoon, right after sun set. My first flight was on a cloudy day and my shutter was at 1/800 ISO 100 EV 0. ND8 would have worked just fine.
2022-6-7
