S/H mini2 refresh care for repair
623 3 2022-6-25
Steven Parker
Flight distance : 252402 ft
Can I return a second hand mini2 in for repair using the original owners refresh care? I purchased the drone several months ago but the previous owner has not removed his account from the drone. I have tried to contact him but have received no reply. It’s my understanding from doing some research, that the refresh care applies to the remote/drone registered and can be returned for repair as it’s the drone registered and not the account. Is this correct? The drone has developed a gimbal calibration error after updating to latest firmware and although the calibration is successful and operates as should during flight and operation, the error remains. I have refreshed the firmware using the assistant 2 but has not rectified the issue, so drone will need to be sent in for repair. My concern is that although I’m flying the drone under my account login, that the drone would be returned to the previous owner under refresh repair. Could you please confirm the information. Many thanks. Steve.
2022-6-25
DJI Thor
Flight distance : 13602 ft
Hi, there. Sorry for your inconvenience. In this situation, you are not advised to use others DJI Care Refresh without the permission of the previous owner. You may try to contact the previous owner first. Thanks for your understanding and support.
2022-6-25
Steven Parker
DJI Thor Posted at 6-25 20:05
If I get the previous owners permission to use the refresh, what confirmation do you require? Do they need to make any changes to the account or transfer details?
2022-6-26
DJI Wanda
Steven Parker Posted at 6-26 04:00
Hello, there. Sorry for your inconvenience. We would recommend you contact the previous owner to unbind the account. As for the DJI Care Refresh services, it is bound to the aircraft. If you want to use the services, you can apply for an online repair case and then send it back. Here is the link: https://www.dji.com/support/repair?from=store_footer
2022-6-26
