smbishop
Flight distance : 2479334 ft
Arc Light Posted at 6-29 13:32
Many thanks for the kind comments all!
smbishop, To light this display I had two open face "redheads" 600w each of 3200K light through an overhead 6X6 silk for a base level light from above, to the rear right of the display I used an Aperture light dome 5600K to simulate moon light. Out front to the left of the setup I had a 1X1 Led 3200K running about 75% output through an 3X3 Silk providing some fill light, and finally I had a small 150w Dedo Light with pattern projector; projecting a faint moon like planet against the black background on camera right. The Osmo Pocket 2 was set for 3200K, shooting at 120FPS at an exposure index of 400. I would have loved to shoot at a lower Exposure index but the with the camera shooting at 120 frames per second and a limited lighting budget I had to rely on the EI at 400. Overall I was pretty happy with the performance of the camera and the gimbal and small size meant I was able to fly the camera into tight areas on set. I think it worked very well in that situation!
Thank you for sharing all of the details, it is quite impressive! |
