Output to external monitor using type c on RC controller .
7606 10 2022-7-17
fans79782605
Flight distance : 5281804 ft
Russia
what solutions are there to display the image from the rc controller from mini 3 to a TV or monitor ..? Found on Ali such inexpensive options? They work ?
2022-7-17
fans79782605
Russia
Блин ,как вернуть свой прежний акк..)
2022-7-17
frankymusik
Flight distance : 27904331 ft
Here:
Mavic 3 forum...!
2022-7-17
fans79782605
Russia
so what ? )
they are compatible and finally there is a right wheel for zoom...
2022-7-17
KnNLmS
Flight distance : 119967 ft
Turkey
Does it really working? Anyone tested?
2022-7-17
fans79782605
Russia
they say it works  with RC ..
need to check ..
2022-7-17
DJI Stephen
Hello there. Good day and thank you for the inquiry. I hope that our fellow DJI Co Pilots who owns the DJI Mini 3 Pro can share and give out what cable they are using and can give out the best recommendation with regards to this matter. Thank you.
2022-7-18
Bashy
Flight distance : 2354357 ft
Fron what I have read, none, there is no video out, hdmi or otherwise. Unless sommat new has been added recently, if there was then the folks with the dji goggles would be all over it
2022-7-18
KnNLmS
Turkey
Anyone tried?
2022-7-18
djiuser_2HMdgBLocwXW
DJI Stephen Posted at 2022-7-18 01:41
I do not know if it works but there is just nothing out there about adding a external monitor or tablet to your DJI RC for people like me that want a bigger screen than the phone sized one they put on the RC Remote. Please post anything if you find it, I have had no luck trying it already
2023-5-29
DJI Gamora
djiuser_2HMdgBLocwXW Posted at 5-29 10:52
Hi, there. Thank you for your input. The DJI RC does not have HDMI input, nor has it been officially advertised to support HDMI output. Moreover, some users may provide a workaround related to this setup, however, as the output feature has not undergone a compatibility test, using the RC  for HDMI output may result in unstable transmission or stuttering. We recommend conducting a test run before any live streaming or image output to ensure a stable connection. Thank you for your understanding.
2023-12-23
