Mini 3 Pro 48mpx picture quality. is this normal ?
12Next >
7601 65 2022-7-24
Mattmatt2235
Flight distance : 271017 ft
Hello,
I'm having weird issues with my Mini 3 Pro.
Everything looks like a painting. Here is 100% of one 48mpx.
What's weird is that yesterday I took a OK picture with less light it was not that weird paiting look...
2022-7-24
Mattmatt2235
Here is the picture taken with much less light yesterday and underexposed, look grainy because I raised luminosity and all but there is details and not that "painting look"... At least it feels like...
2022-7-24
juan55
Flight distance : 577096 ft
https://forum.dji.com/forum.php? ... D776%26typeid%3D776
There are already complains about it .... Please open a case with DJI Support
2022-7-24
Labroides
Flight distance : 9991457 ft
Mattmatt2235 Posted at 7-24 02:14
[view_image]Here is the picture taken with much less light yesterday, look grainy and all but there is details and not that "painting look"
Perhaps the metadata would have some clues.
If you can upload both full-size images to dropbox or similar and post a link here that would help.
2022-7-24
Mattmatt2235
Labroides Posted at 7-24 04:04
https://1drv.ms/u/s!AkD9_wf2HJmnhecapt3GHtBFl0MFUg?e=WanspW
2022-7-24
hallmark007
Flight distance : 9827923 ft
What shutter speed were they taken at , were ND filters used slowing down the SS. The examples above look to be cropped 200/400%. But they look very poor and very soft.
2022-7-24
SrMi
Flight distance : 3425 ft
The brighter one has blown highlights. Apply some negative highlights in the post to recover the lost data.
The darker one has more noise. An image with more noise can sometimes look as if it had more details.
2022-7-24
Mattmatt2235
Thanks, it has nothing to do with highlights or shadows,
I tried every settings possible, with nd to reduce shutter speed, without with higher shutter speed, low iso, high iso...
I stated that the last one is grainy, it was dark, but it's ok to me, I know what to expect with this kind of sensor. The problem is the first one, it's in auto, but as I said i tried several different settings.
It's 100% crop not more. Look at original file.
2022-7-24
Labroides
Neither one looks good at 100%.
But shutter speed isn't the problem.
The one you identified as the problem was at 1/600th sec.
**edit** .. it was 1/1600th
2022-7-24
Mattmatt2235
Labroides Posted at 7-24 07:06
1/1600th
Yes, not shutter speed problem as I used a Nd and got down to 1/60th and had the same problem...
2022-7-24
Labroides
Mattmatt2235 Posted at 7-24 07:08
1/1600th
Both look soft and mushy, but neither is a good shot to show how well the lens is performing.
There's no hard detail, just thousands of distant leaves.
To properly get an idea of the camera, try shooting something like a well lit house from 10-15 metres.
And ND filters are never going to improve stills unless you have a specific reason to force a long shutter speed.
2022-7-24
hallmark007
1/1600th
Why use ND filters on this type of subject surely 1600th SS will give you a much sharper image . If the weather was completely still 1/60th will be sharp enough but if its windy then 1 /60th will not give you a sharp image. Although the gimbal is pretty good on Mini 3 the craft moves around a lot in the wind.
2022-7-24
Mattmatt2235
Labroides Posted at 7-24 07:32
Are you often shooting things at 10-15 meters with your drone ?
I'd say what a was shooting was actually 10-15 meters...so...
The Nd was to lower the shutter speed to see if the problem remain.
None of the shots I've provided was with an ND.
You should read carefully before randomly responding.
I've had phantom 4 pro, mavic pro, anafi, air 2 and now mini 3 pro... i've never seen something like that that is why i'm asking.
2022-7-24
Mattmatt2235
hallmark007 Posted at 7-24 07:48
Did you read ?
I tried different settings to see if somethings were different, none of the pictures i've provided was with an ND.
It was not flying, I shot from my windows on a table.
2022-7-24
hallmark007
Mattmatt2235 Posted at 7-24 08:32
Did you read ?
Well reading is not really a strong point with yourself. I clearly asked the question in post 7 regarding the use of ND filters.
In post 11 I quote you “Yes Not a shutter problem as I used a ND and got down to 1/60th and had the same problem. So its extremely difficult to know now what the shutter speed was and why you would try slowing down the SS to get a sharper image, that makes little sense.
But obviously I can’t help here, so good luck..
2022-7-24
Labroides
hallmark007 Posted at 7-24 08:53
Pot ... meet the kettle
The shutter speeds are there for anyone to read in the image metadata.
Just like I did and posted details too.
2022-7-24
Labroides
Mattmatt2235 Posted at 7-24 08:30
Not often, but if I wanted to check the lens and image quality, I would.
And I'd make sure the test shot had lots of well lit hard detail instead of just distant leaves.
So there was no hard detail within 10-15 metres.
Almost all the shot is soft background.
The only thing an ND filter does is to force a slower shutter speed.
A slower shutter speed won't help improve sharpness.
It could do just the opposite.
Randomly responding?
There's nothing wrong with my reading or comprehension.
And I actually know what I'm talking about too.
2022-7-24
yannick_c
Flight distance : 242946 ft
A side effect of the quad Bayer maybe. Some kind of worm look like here?
https://forum.dji.com/thread-218278-1-1.html
2022-7-24
Mattmatt2235
Sorry, english is not my first language.
I've posted the DNG. Your question was responded at post 10. I said not a shutter speed problem because I tried other shutter speed.
The shutter speed IS in the message you quoted, so maybe not THAT difficult.
The picture is at 1/1600th. It was a bright day and it was in auto.
I tried ND to slow down the shutter speed to see if it had any impact on the problem, just in case (too much light on the sensor ? god I don't know, I tried). Problem was the same at different ISO et Shutter Speed. I tried all settings to see if anything would change, shutter speed was one of them, it doesn't make much sense but I tried... With ND 1/60th, it's fine for "landscape" with no wind, don't worry. Congratulation you know your exposure triangle, does everybody has to be aware of that ?
2022-7-24
Mattmatt2235
Labroides Posted at 7-24 09:06
I know, I know, I just tried different settings, feels like what a shutter does is some kind of secret only members here knows about...
The whole picture is like that weird effect, i've never seen this before, that's why i'm asking ! and you guys are all ND this, Shutter speed that...
2022-7-24
Mattmatt2235
yannick_c Posted at 7-24 09:06
maybe... Thank you for the link.
2022-7-24
Labroides
Mattmatt2235 Posted at 7-24 09:12
I asked to see the metadata to see if slow shutter speed might be a factor.
It was a simple obvious possibility and easy to check and eliminate.
There's no mystery about shutter speeds and what they do.
A slow shutter speed increases the chance of motion blur if the drone or the subject is moving.
A fast shutter speed minimises that possibility.
2022-7-24
Mobilehomer
Flight distance : 18150351 ft
Auto or manual focus? It looks out of focus to me.
2022-7-24
Mattmatt2235
Labroides Posted at 7-24 09:23
I was being sarcastic.But I understand why you asked of course.
2022-7-24
Mattmatt2235
Mobilehomer Posted at 7-24 09:44
Autofocus
I tried manual focus, different "steps" to see if something was off somehow and nothing...
2022-7-24
SrMi
Mattmatt2235 Posted at 7-24 07:03
I've been looking at the original files in RawDigger and Lightroom. Have you tried applying negative highlights to the bright one and running it through Topaz Sharpen AI? test-1.jpg
2022-7-24
NewToy
Flight distance : 3395469 ft
Tip: The post by the administrator or moderators shield
2022-7-24
Mattmatt2235
NewToy Posted at 7-24 12:53
Your dealing with a clown
wow nice thank you. So much hate. Thanks.
2022-7-24
Mattmatt2235
SrMi Posted at 7-24 12:47
Hi,
Yes for highlights, doesn't change a thing. As for Topaz no. I'm just trying to know if it's normal or not.
2022-7-24
NewToy
Mattmatt2235 Posted at 7-24 12:59
its not from me as i visit here at most once a week.Just setting the record straight.
2022-7-24
Mattmatt2235
NewToy Posted at 7-24 13:03
I did not understand but I've read a few of your message here, it's always negative and condescending so i'm just going to ignore you.
2022-7-24
hallmark007
Don’t encourage him he’s been banned over 30 times on this forum, he will add nothing to your thread except to cause consternation.
2022-7-24
Mobilehomer
How does the picture look when taken at 12mp?
2022-7-24
Mattmatt2235
It’s less obvious because of the lower resolution, but I don’t think it’s normal... I’ll do more test tomorrow.
2022-7-24
MarcoDi
I also see in a lot of details like grass, leaves etc kind of painting effect. I don't like it too much and would like to have an option in menu to have more noisy and less painted pictures (if this painting effect is because of denosiing).
I found today something worse than that in repeating pattern on the roof. This crop of this area looks really bad for "PRO" drone.
On video when I flew over it, this looks like moving V pattern but much more subtle than this photo.
Some time ago I have seen a test of mini 3 pro camera on kind of test board. There was some artifacts in small repeating patterns but nothing like this error on roof...
2022-7-24
Labroides
You've misinderstood.
He wasn't referring to you
2022-7-24
Labroides
MarcoDi Posted at 7-24 14:41
Search "Moire" to see what that's about.
2022-7-24
DJI Stephen
Hello there Mattmatt2235. I am sorry for the trouble this has caused and thank you for reaching out. Since we are having this issue with your new DJI Mini 3 Pro, I would recommended for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do our best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-7-24
NewToy
hallmark007 Posted at 7-24 13:33
only you would fabricate and take the time to dream up numbers.
2022-7-24
MarcoDi
Labroides Posted at 7-24 18:15
Ups... You have right... I just never seen before so bad moire example on my apsc without low-pass filter and I forgot about it and didn't connect the dots. In this case, my bad to mention it here.
2022-7-24
12Next >
