Brand New Drone - No Signal Error 30008
7144 17 2022-8-4
Moji
Hi,
I'm having a problem with my brand new Mini 2!  No Signal - Error 30008
I turned my new drone on, activated and then updated the framework and this error appeared. It doesn't connect to any satellite at all. I have tried different places but still no luck!
This is my second drone I received as replacement form DJI. My previous mini 2 had no problem finding satellite.The only issue was the Gimble.
Any resolution?
Thank you
Moji
error 30008
error 30008
2022-8-4
DJI Stephen
Hello there Moji. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please test your DJI Mini 2 outside in an open location so that your DJI Mini 2 can receive a stable GPS signal for us see if the error codes on the DJI Fly application will show again. Please keep us posted for further assistance. Thank you.
2022-8-4
Mhinc
Flight distance : 151467 ft
You typically won't get a SAT lock inside, there are far too many things to block a lock such as RF, Magnetic Interfence, WALLS, etc.   This is common.  Go outside and you should lock on to enough SATs in about 30 seconds.
BUT if you have tried flying outside and you are still getting the No Signal - Error 30008, you may have got a bad firmware download. I would suggest redoing the most recent firmware and trying again
2022-8-4
DJI Wanda
Hello, there. Sorry for your inconvenience. Would you please refresh the firmware. Then, restart the drone outside and try again? For your feedback on our replacement services, would you please tell us your case number? We will check and confirm with our teams. Thanks.
2022-8-5
Moji
Problem solved! Thank you for your help !
I just had to go somewhere like a park to get signal.
I used to get a strong signal in my backyard; even in my room but it seems not anymore!
cheers
2022-8-7
DJI Natalia
Moji Posted at 8-7 21:21
Thanks for the update!
We are glad to see your problem is resolved.
If there is anything else that we can help with, you can contact us here anytime as well.
2022-8-7
Halski78
Poland
I have same. I refreshed firmware. Bought 10.03.2024 and never catch GPS and any satelites. Tried on many diffrent places such a park, open space.
3-24 05:05
DJI Diana
Flight distance : 2408 ft
Halski78 Posted at 3-24 05:05
I have same. I refreshed firmware. Bought 10.03.2024 and never catch GPS and any satelites. Tried on many diffrent places such a park, open space. [view_image]
We feel sorry for the situation you encountered. If all measures above have undertaken, we suggest to send it back for testing. You may refer to this link and create an online repair request, or if you encountered difficulties, you may contact our team to help you arranging/creating a case for you. Thank you for your patience.
3-24 10:05
Ravikant rk
India
Today (09April2024) I got same problem after I update new Firmware. No GPS, Fly with Caution Error Code 30008. . Before update I fly it without error.
4-9 02:17
Ravikant rk Posted at 4-9 02:17
Hi there, may I ask if you've tested it outside in an open area to see if this message still exists?
4-9 02:21
Ravikant rk
India
I did not get the error outside, but before update it was still work inside also. I'm just thinking about error (Not Stable Hovering fly with caution). what if I record wedding videos in hall? is it stable to record videos?
4-9 21:53
Ravikant rk Posted at 4-9 21:53
This message will appear when there is no GPS signal, the takeoff is permitted but there is no GPS. It is not recommended to do so unless in special circumstances or necessary conditions are met because most DJI aircraft use GPS positioning. However, indoor GPS signal is poor (and sometimes there is no GPS signal), which may affect the aircraft’s positioning accuracy making the aircraft likely to drift and crash.
4-9 22:29
Ravikant rk
India
I want to go back with old firmware. is it possible?
4-11 20:44
Ravikant rk Posted at 4-11 20:44
Hi there, may I know the model of your device? Is there any issue with the current firmware?
4-12 01:14
Ravikant rk
India
DJI Mindy Posted at 4-12 01:14
I have mini 4 pro.
4-12 20:15
Sorry to tell you that the Mini 4 Pro does not have firmware that supports downgrade. May I ask if there is any issue with the drone?
4-12 20:33
djiuser_gtj07cZrPaIP
India
DJI Mindy Posted at 4-12 20:33
Hi..I am also facing this same issue but can I downgrade my DJI mini 2 se ?
4-27 01:17
DJI Thor
Flight distance : 13602 ft
djiuser_gtj07cZrPaIP Posted at 4-27 01:17
Hi there, may I know have you tried to refresh the firmware and tried it outside in an open area to see if it could work?
4-27 01:58
