stefan.gudmunds
Sweden
I have the exact same problem with the aircraft claiming it already has the same firmware installed or the "new" one is older than on the aircraft.
My procedure was as always: download update, unzip, place the .bin in the root on memory card, put in aircraft with full battery, and start aircraft.
After the initial green and yellow flashes during a couple of seconds the aircraft continuously do the four beep sound and red leds glowing. Checking the text file gives:
Result: Success.
========== 2015.06.20 13:40:45 =====================
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
.. a lot of same output here ..
========== 2015.07.05 17:35:16 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
I have no clue on what to try next! Tested with different sd cards and downloaded update a couple of times. Nothing. I don't dare to update remote control until aircraft is updated.
Anyone with some thoughts? |
