So basically I went out flying to drain my battery from 50% to 15%, until a sudden low voltage warning appeared - not low battery, and landed immediately at about 30%. Battery has only been charged 20 times... Any suggestions or comments on why this happened???
The same thing happened to me, but was just after I did the FW update on that battery. Recharged to 100% and have tested it twice now down to 20% with no problem
Medevon Posted at 2015-8-6 16:07
What do you mean? The only setting I am aware of is viewing the voltage on the main screen?????
In addition to the rest of the battery display screen, it appears you need to read a little more closely in the manual. The condition of your battery is directly related to automatic operation of the RTH (Return To Home) feature.
