Agras T-30 Spare Parts Kit
2143 4 2022-8-15
ProAgroAgras
Panama
Hi, I am new acquiring Agras T30.
I am only getting one for now, Can someone share a suggested list of spare parts that are mostly needed?
Thanks,
2022-8-15
Drone_Agras
Flight distance : 1383983 ft
Hi,
I suggest that you will need a propellers CW and CCW at first time, later you must have selenoid valvs, nozzles, pump.
The most important thing is that you must do maintenance cleaning the motors, pumps and rest of parts for avoid futures faults.
2022-8-16
kapchur.us
Flight distance : 1248743 ft
Extra batteries has been a big deal for us. Depends on how many hours per day you fly, but we had to implement two generators and four chargers. I think we have 8 batteries. All of this to keep two in the air for 5-7 hours of flight time per day. We use the spreader system only so far, and with that we go through a couple of sets of blades per week. Mostly because of “involuntary landings”. If it’s hot where you are, and you’re carrying heavy loads you may experience ESC 3 overheat messages. (ESC 3 is motor 3, which if you’re looking down on the drone, starting at the front near the two knob RTK radars is motor 1, then counter clockwise the motor numbers go up). We use a cold wet rag while reloading to cool motor 3 while reloading/battery changes. If you’re not using the RTK base station you should probably turn off the RTK Position assistance, not necessarily the orientation assistance though. If you leave position assistance on, it will usually prevent you from taking off.
2022-8-16
ProAgroAgras
Panama
kapchur.us Posted at 8-16 04:05
Thanks for the over heat motor tip. greatly appreciated. Yes I run in hot weather all the time.
ESC Cards are spare for T-30 same as for MG's before?
I have an MG fleet that I plan to replace. I am starting with one to see if I keep T30 or wait for T40.
2022-8-18
Arnaud LRC
Flight distance : 333323 ft
Belgium
Hi,
Does one of you know where i can get a small flow hopper gate for the spreader 3.0? I either didn't receive it with the spreader or I lost it.
This in order to sow at about 2 - 3 kg per hectare.
Regards
2023-2-6
