Dummy battery
1611 10 2022-8-18
Adiemask
Flight distance : 185659 ft
Is there such a thing as a 'Dummy Battery' for the M3P? It would be good if a dummy battery could be inserted into the M3P for transportation purposes thereby allowing the three batteries I have as part of the Fly More Kit (along with original battery) to be carried in a 'Lipo Bag', specifically for flights etc. Is this something that can be 'made' by any of you guys out there with 3d printers?
I worry about carrying the drone without a battery inserted for fear of getting 'rubbish' inside the drone!
2022-8-18
Mavic57pro2
Flight distance : 3772247 ft
I always leave a battery in the drone, keeps dust etc out. Never had a problem in 5 years with DJI products.
2022-8-18
The Saint
Flight distance : 5902228 ft
it's probably too early in the life cycle but general dead batteries or battery-for-parts-only show up on ebay for really cheap.
2022-8-18
Adiemask
Mavic57pro2 Posted at 8-18 06:50
I know that I can leave a battery in, it’s just me being me, I just think it would be good to have a ‘dummy Insert’ (read ‘Battery’) thereby carrying all my three batteries in a Lipo Bag for flying etc. As you’ve pointed out it makes sense to have an insert in the drone to avoid ingress of dust/particles.
2022-8-18
Sean-bumble-bee
Flight distance : 15997 ft
Make one from a block of wood. etc,. Dummy batteries probably exist .....for shop display models but with Mavic Mini dummies they contain weights, presumably to bring the dummy as a whole to near 250g, Plus those battery cases were/are secured by screws fitted inside the drone's shell doing assembly.
2022-8-18
Drone Jockey
Buy a piece of foam (the stuff for cheap pillows), cut it to the size of a battery and be happy ;-)
It is cheap, easy to cut with scissors and should seal the battery compartment good enough, right?
PS: Not the full length of the battery is needed, just the width and height should be relatively precise.
2022-8-18
Beta5K
Flight distance : 196880 ft
Drone Jockey Posted at 8-18 09:53
Not sure about OP, but for me personally, I would like a dummy battery to also prevent the drone from cracking due to the thin walls. And the case is a soft case, compared to the Mini 1 case.
I'd be okay if the case was a semi-hard/hard shell case. Was a little worried this past weekend after putting the 3 batteries in a lipo bag on my carry on, and the drone without the battery in the bag.
2022-8-18
DAFlys
Beta5K Posted at 8-18 12:42
You probably should carry the drone on as well as sometimes security want to check the batteries are batteries which requires powering on the drone with the batteries.
2022-8-31
DAFlys
I would just put the drone in a sealable bag if you are concerned about dust etc.
2022-8-31
PJL-Chicago
Flight distance : 131991 ft
Adiemask Posted at 8-18 07:03
Agree with you 100% Asked the exact same question on mini 3 facebook group.
2022-9-24
Adiemask
PJL-Chicago Posted at 9-24 15:02
Did you get a meaningful reply?
2022-9-24
