Questions about Ronin 4D E Mount Lenses and focus motor
1594 4 2022-8-22
Samwize87
Hey everyone,
So I recently aquired a Ronin 4D 6K and have been having some issues with focus and calibration when it comes to E Mount lenses. I've cross referenced my Sony GM lenses with the ones DJI's site says are compatible with the 4D, however none of them are able to rack focus. Then when I try and calibrate them auto calibration always fails and I'm unable to manually calibrate as turning the focus wheels on the camera don't do anything and the focus meter on the right side stays at infinity. A source I reached out to for help says the reason is because my lenses don't have focus stops and only lenses with focus stops are compatible with the 4D's calibration. Is this true? Is there something else I'm missing? Any and all info is appreciated. I'm up to date on the latest firmware with the camera too if that info helps.
Thanks so much
Sam
2022-8-22
AnthonyMarkSaul
Same issue with 3 GM lenses on E Mount on 4D. Keeps jumping to infinity. Useless Autofocus.
2023-8-8
thefilmguy102
Switzerland
Hi Sam, have you found a solution?
1-11 01:31
fansc73009c8
I did a whole movie with sony 14mm G, 35mm G, and 25 mm G -  and all worked fine. after 3 weeks the automatic stop and then also the focus stopped working. as if the connection was lost between camera mount and lens. the 14 mm works still fine. please DJI guys respond!!!!
DJI native lenses still work perfect. but I need other lenses for minimum focus and stop 1.4
3-9 00:37
fansc73009c8
AnthonyMarkSaul Posted at 2023-8-8 05:28
hi, I have the same problem, did you find a solution?
3-14 20:19
