Controller Woes P4Pro RC P4Pro plus AC
507 0 2022-8-29
kimberlyo
Hi.
I purchase a controller that was advertised as a Phantom 4 Pro controller and came in a box with Phantom 4 Pro manuals in it, so I'm assuming that the seller isn't telling fibs. ie that it really is a Phantom 4 pro controller. The problem is, it is marked on the bottom GL300C with no reference to version B. How would I identify it as being a version B if it is, and how do I get this thing to connect to the Phantom 4 pro plus? I wanted to replace the Phantom 4 Pro Plus controller that does not suit my needs.
When I connect the RC to DJI Assistant 2 for P4 it tells me that it isn't supported. It has no SD card slot so I'm lost as to how to update the firmware as well- which I guess could solve the problem, if it really is a version B.
I connect the RC to my iPhone 10 running DJI Go 4 and with wifi on. when I go to Advanced settings, it shows RC version 1.6.0 but will not connect to the aircraft
No matter which method I use to attempt to link the RC and aircraft, it times out.
The serial for the RC is 045JD027020358
Please can someone assist?
2022-8-29
