Buzzyone
Flight distance : 4647913 ft
Not all USB chargers are created equal! Currently Im using the MacBook Pro charger to charge the batteries, its delivering the maximum 70W the batteries can take. I also have a 65W DJI Charger from my Mavic 3. which is also working well.
Essentially you need a PD charger capable of delivering 70W+ if you want the fastest charge, secondly you will only get this when using a cable with a USB-C at both ends & rated to deliver this power. There are a few 100W cables on Amazon, I'm using an Mcdodo 100W cable with built in power display.
The 65W DJI unit has an attached USB-C cable and a USB-A socket, which is handy for the remote, but won't deliver the full 65W through the USB-A connector.
Intresting note, the single battery charge adapter that is shipped with the Avata only charges the battery at 48W, the Avata Charging Hub, that comes in the flymore kit, charges at 70W.
