L1 stops collecting data midway through missions
1691 6 2022-8-31
bbegroup
I've had the L1/M300 combo for well over a year now and have never experienced this problem. Just like the title says, everything works great at the beginning of a mission - but after the 1st or 2nd battery change, the L1 will not start recording data once it returns to where the mission was paused. Just a blank screen and no lidar data being recorded. The RGB camera functions properly and takes photos at timed intervals like it should, but the L1 data recording is intermittent. Sometimes after several reboots and time wasted, I can get the L1 to function properly again, but not everytime. The issue is present in both mapping and manual data collection.
I was pretty certain/hopeful that the L1 was faulty and being desperate to complete the project, I elected to have a loaner L1 overnighted to me... only for it to arrive and experience the same issues! I'm stumped. The odds of 2 L1's being faulty are very slim, but there are no issues with the m300, controllers, batteries, or base station. Everything is up to date and functioning properly. Both the P1 and H20T work as they should and have completed missions since the onset of this problem.  I even tried downgrading the m300's software thinking that may help. It didn't. The lidar worked until the 2nd battery change and then cut out again.
I am currently still on this project and would love any feedback.
2022-8-31
LV_Forestry
Flight distance : 4726654 ft
Latvia
It could be Pilot2 issue. I recommand to try with UGCS trial version to see if the problem continue.
2022-9-1
AlpRS
Switzerland
Same issue here. Any news on this problem?
2022-10-11
patiam
Flight distance : 1118740 ft
Also try swapping SD cards. Sometimes the old tried and true cards wear out.
2022-10-11
SurveySays
I am having this same issue.  Any updates on the problem?
2022-11-22
djiuser_SjXoCRwfPYR2
Flight distance : 3986 ft
Bulgaria
Same issue here. L1 collects data but at the end when rendered the part is missing - so we just waste battery. Continuing a stopped lidar mapping is not working well at all..
4-11 05:06
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
djiuser_SjXoCRwfPYR2 Posted at 4-11 05:06
I never had this issue but I would recommend : factory reset your controller and check/replace SD card.
4-11 23:33
