Avata Motion Controller Charging issue
6048 21 2022-9-1
artaldrich
Flight distance : 170758 ft
I cannot get the new Avata motion controller to charge.
Hvae tried numerous chargers and cables. No issues charging the batteries themselves, just motion controller.
Are the LEDs suppose to flash when charging?
DJI support queues are long right now...
2022-9-1
statuswrex
I had the same issue with dif charging bricks/cords. Seems finicky but yeah it’ll blink when charging.
Example: my MacAir brick/usbc-usbc cord will charge the batteries but not the controllers.
I have 2 motion controllers, both react the same way to certain charging solutions.
2022-9-1
fans30216b1a
Flight distance : 395062 ft
I had the same issue. I found that if I use a USB A to USB C cable it charged just fine. I couldn't get it to charge using a USB C to USB C cable.
2022-9-1
Lundis
Flight distance : 168314 ft
Norway
I had the same issue. I found that if I use a USB A to USB C cable it charge, but lights are blinking very fast. When charging battery its slowly blinking.
2022-9-1
djiuser_RhYouXK2PGnm
fans30216b1a Posted at 9-1 10:35
That worked for me as well, USB-A to USB-C and it started charging right away. Thanks for the tip!
2022-9-1
Buzzyone
Flight distance : 4647913 ft
The Motion controller does not support PD charging.
USB-A to USB-C is the way to charge it.
2022-9-1
DJI Stephen
Hello there artaldrich. I am sorry for the trouble this has caused and thank you for reaching out. As posted above kindly please try using a USB-A to USB-C to charge your DJI Motion Controller to see if still the issue persist? Kindly please keep us posted. Thank you.
2022-9-1
Lundis
Norway
DJI Stephen Posted at 9-1 19:15
[view_image]
So, what is this then? Is this something DJI did know about and keep a secret? What about putting this cable in the box aswell!
2022-9-2
Iczeman
Flight distance : 8367569 ft
Czechia
I can confirm that DJI Motion Controller is very specific as only two out of about ten of my chargers/cables are capable to charging it.
2022-9-2
fans630ddc40
Appreciative of the tip here - it’s been driving me crazy all day trying to figure out .
Sounds like a bug and warranty issue as the instructions nor the kit mentioned it or provided the rare unicorn cord it shouldn’t require in the first place .
2022-9-5
fans630ddc40
2022-9-5
artaldrich
DJI support was clueless and told me to start a return with the reseller.
This needs to be documented better for sure.
2022-9-5
djiuser_jpxjeM4oZZsB
This worked for me too, I don't understand why.
2022-9-9
Buzzyone
Lundis Posted at 9-2 00:01
Not a secret it’s in the manual.
2022-9-9
Dave In NH
Flight distance : 13436247 ft
I believe this is a cable issue. I managed to find a USB C cable that works. The chargerbitself doesn't seem to play a role, just the cable you use. I bought a 65 watt car charger kit from Drone Valley and the cable that came with it can be used to charge the controller. I also have had luck with a Voutz USB C cable as well. Not all the Volutz cables work, but I have one that does.
2022-9-15
KLRSKIR
Flight distance : 28368625 ft
Dave In NH Posted at 9-15 14:27
I too use the Drone Valley 65W car charger as well as their wall plug with no issues. Just need to use an old "A" to "C" cable. It also works with a 120W and 240W brick.
2022-9-15
fans2a15ec1c
Flight distance : 16381 ft
THANK YOU!!!  I have not been able to charge my Motion controller for a week!  And with my two-stick controller on back order for a month, this left me with no way to fly my new drone.  Why was a piece of paper, with the solution in 72-point type, not included in the box? This is a major oversite on DJI's part. So was designing the controller this way.
2022-9-19
Kelvin Ross
USB-C to USB-C didnt work for me either.  I used the charger I have for Mavic 3, used the USB-A - USB-C cable that plugs into the mavic 3 charger.
2022-9-20
DJI Natalia
artaldrich Posted at 9-5 17:38
Hi, there.
We are sorry for the inconvenience caused.
We will confirm this problem with our support.
May we confirm if your problem is resolved now?
If not, please use 5v1A/2A charger.
Thank you.
2022-9-20
katadair
Buzzyone Posted at 9-9 23:44
Not a secret it’s in the manual.[Image]
The problem is is that nobody has any freaking clue what a PD charging block is.
Use an old Apple iPhone Square charging block with a USB old style connector to USB-C cable.
2022-9-23
LGustavo
Brazil
I'm having the same problem, but I'm going to try to use the usb a to usb c cable, as they said here.
2022-11-6
djiuser_7Iq7Tcb7zMUY
Thanks for the tip about using an USB-A to USB-C cable to recharge our DJI controllers. I wasted hours of my valuable time trying to figure it out!
DJI team, get your act together! This is an unacceptable flaw in your product design and in your support documentation! I will not recommend this device to others until this flaw is fixed.
2023-1-4
