Charge with DJI FPV Charging Hub
3929 15 2022-9-1
Ranger7777
Flight distance : 152782 ft
I do not have my Avata, drone only, yet.  Looks like about 3 weeks.  But looking at pics of the battery, and the USB charging hub in the Avata Flymore kit, i see some similarities.
So, can the DJI Avata batteries be charged with the DJI FPV charging hub.   That would be awesome!
2022-9-1
DJI Stephen
Hello there Ranger7777. Good day and thank you for reaching out. I am sorry to say that the DJI FPV Battery Charging Hub ( https://store.dji.com/product/dji-fpv-battery-charging-hub ) is only compatible with the DJI FPV Intelligent Flight Battery ( https://store.dji.com/product/dji-fpv-intelligent-flight-battery ). Thank you.
2022-9-1
alex_markov
Flight distance : 39646480 ft
Bulgaria
DJI is Very careful Not to have any compatibility which will Prevent You from buying New products from them and reuse Your current items
2022-9-2
frankymusik
Flight distance : 27904331 ft
alex_markov Posted at 9-2 22:10
This is really not correct at all!
I now own both, the FPV Goggles V2 and the Goggles 2.
The V2 is "a hundred times" better to me along with the Avata.
A better field of vision, wearable with glasses, much easier to navigate menus...
Sits perfectly on the head without pinching.
And the two controllers from the DJI FPV work great.  In particular, the FPV RC2, which is a real pleasure to use, is perfect for the Avata...
All fully compatible, and the V2's transmission power is even better!
2022-9-2
alex_markov
Bulgaria
frankymusik Posted at 9-2 22:35
Ок - You are correct but there are far more examples of incompatibility - especially in the battery/charging department thank god USB-C started kicking in
2022-9-2
frankymusik
alex_markov Posted at 9-2 23:25
... and, also consider the compatibility of the
- DJI RC Pro
- DJI RC
- RC N1
regarding the many drone types...
Batteries have to be specially designed for a drone, there is hardly a way around it...
And yes, recently everything can be loaded via USB-C, which makes a lot of things easier!
2022-9-3
Buzzyone
Flight distance : 4647913 ft
Worth also noting -
The DJI Avata Charging Hub will charge the batteries at 70W with a compatible USB-C PD Charger
The single Adapter will only charge at 48W
Neither the Motion Controller or the FPV Remote Control V2 are PD compatible so cannot be charged with a USB-C PD Charger, you need to use a 5V USB-A charger with a USB-A to USB-C lead.
USB-C is not a standard, far from it, the only thing about it that is standard is the connector, there are many different implementations by manufacturers as to how its configured. Reminds me of when RS-232 was a 'standard' which drove people insane with the various connection, handshaking and crossover configurations.
If you connect an iPad Pro using its USB-C connector to the RC-Pro, it might not work, un-plugging the iPad turning the connector upside down and it works!!
2022-9-3
Buzzyone
Hmmm sure about that! USB-C is far from standard where power delivery is concerned!
2022-9-3
alex_markov
Bulgaria
Buzzyone Posted at 9-3 01:44
USB-c is far better than all proprietary chargers for each and every device
2022-9-3
alex_markov
Bulgaria
Buzzyone Posted at 9-3 01:43
Worth also noting -
Yes And No most USB-C chargers support many "protocols" for charging and I charge my remotes with a 65W USB-C charger just fine as it adjusts according, Not everything is perfect But have nothing to do with RS-232 I remember those days very well   even had a customer who build "LAN" based on RS-232  with a "switchboard" made of wood and wires
2022-9-3
The Saint
Flight distance : 5902228 ft
dji needs to create a charging hub with changeable inserts so you can charge multiple batteries at once from different models.
like this where you change the inserts:  https://kleinelectronics.com/6-s ... it-battery-charger/
2022-9-3
CagomoC FpV
Flight distance : 480026 ft
i have both fpv and avata i plug in the charger that came with the avata battery using a power charging cable from my osmo action camera usb-a to usb-c into the usb-a port from the fpv charging hub where you can charge your goggle battery and remote control it takes longer about 1 hour and 20mins but still works been doing for a while now no issues. i think slow charging any battery is better for it.
2023-2-7
The Saint
i think we all know there is a huge about of compatibility just that we are taking it for granted.  the incompatibility comes from evolving technology and design; certainly no nefarious planning.  think about where we were 10 or 20 years ago when practically nothing worked with each other.  it was a nightmare and i still have the chargers/batteries/cables/misc to prove it.
2023-2-7
Big Fil
Flight distance : 1113484 ft
My favorite feature is that i'm able to charge my Avata batteries, google battery, and motion controller using my 65w Anker power adapter..........but NOT the FPV controller 2. For some reason i have to use a completely different power adapter just to charge the FPV RC2 controller. That's just annoying TBH!
2023-2-7
Fpvskip
Flight distance : 52772 ft
Big Fil Posted at 2-7 13:36
I am using the Anker 735 charger too. Great unit. 2 USB-C and one USB-A with 3 amps.
Charges everything simultaneously.
Why is the RC-2 Controller 2 not charging?
2023-2-7
freedom2000
Flight distance : 519747 ft
Hi,
I am using a PC (Dell) 65W charger and it works perfectly for DJI's batteries. But no way to use it for the GooglesV2 nor the motion controller.
And as said I do prefer to start "fast charging" of the batteries at low current. So I do use the single Batt charger instead of the hub chager. 2,8A vs 4A. This gives a huge difference when looking at the temperature of the cells.
And I do also charge the batteries to 60% to get a nice storage mode condition.
See this post to get a DIY smart/smart charger
2023-2-13
