frankymusik
Flight distance : 27904331 ft
The Saint Posted at 9-2 13:02
my guess is they had very little good alternatives to place the microsd card. it's a design issue and when laying out board, there's not a lot of room to work with and you don't have a lot of choices especially when the drone is small. most of us old school depend on the microsd but one of the big reasons (again, my guess) for including on-board memory is so you don't have to work with the microsd card. it's likely that half of the users probably won't even bother to install a microsd card, does it even come with one?
dont have the drone in front of me; look it over. any suggestions on where else you would have placed it?
... that's what I thought too, that the internal memory might be good enough.
But, it lasts a little more than the flight time of one battery, which is a shame...
And, to retrieve this data, you have to plug in the USB cable again, and that's even more problematic on the road than when you're working on the PC at home...
So you have to practice a bit to remove the SD card, or you can use a suitable USB-C cable that fits into the connector relatively easily...
By the way, to get the data from the Avata you don't need to insert the battery, and the Avata doesn't have to be switched on either, just connect the USB-C cable... |
