Mini 3 screw stuck
12Next >
10633 51 2022-9-4
fansca04d5a3
The propeller screw was stripped while using the included screwdriver, Tried to fix it and ended up breaking the head of the screw now left with it stuck in the screw socket.
Any ideas on how to remove this, or am I going to have to ship to get it fixed?
2022-9-4
fansca04d5a3
The propeller screw was stripped while using the included screwdriver, Tried to fix it and ended up breaking the head of the screw now left with it stuck in the screw socket. Any ideas on how to remove this, or am I going to have to ship to get it fixed?
2022-9-4
fateofangel
Flight distance : 1397238 ft
Poland
you have to drill it with very tiny drill, im not sure how hard the screws are but looks like hard ones, please wear protective glasses if you want to try this on your own, the drill can be easily broken, you have to be patient,
The best option for you is to contact support / servcie and they will replace all arm probably about 50$ cost
2022-9-4
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the unpleasant experience. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your valued support.
2022-9-4
Bashy
Flight distance : 2354357 ft
Send it in, it should be done under warranty
2022-9-4
DAFlys
I do wish we had quick release props on the mini drones.
2022-9-4
Bashy
DAFlys Posted at 9-4 23:03
more weight, i bet it would take it over the 250g
2022-9-5
DowntownRDB
Flight distance : 1722 ft
This is another reason we need quick release props on the Mini 3 Pro.  The screwdriver that is supposed to come with the Mini 3 is substandard.  Mine did not come with one but a friend showed me his and it's cheaply made, which is also why I use the wowstick 1F+.
2022-9-5
DowntownRDB
That would absolutely great.      Probably didn't use quick release props as their use would put Mini 3 over the 249G mark.
2022-9-5
DAFlys
Bashy Posted at 9-5 03:56
Could be right.  but it can't weigh that much more surely.
2022-9-6
DAFlys
DowntownRDB Posted at 9-5 04:12
Hard to believe it would add that much weight.
2022-9-6
FPVin
Flight distance : 300502 ft
You will need to get the right size but this is the tool.
Screw Retrctor
2022-9-6
DowntownRDB
DAFlys Posted at 9-6 01:27
You've got me curious now.  I need to weigh the props for the mini 3 and compare that to the weight of the props for the Air 2S with the quick release props.  I know they are different sizes but I think the connecting part of the props  and also on the motor could be added weight.  Thenn again, I could be totally wrong.
2022-9-6
DAFlys
DowntownRDB Posted at 9-6 09:03
Don't forget the Mini3 also weighs less than 249g,  usually 245g I understand.
2022-9-7
chillibadger
Flight distance : 233064 ft
Could you get a set of these to fit the screw size?
2022-9-7
chillibadger
chillibadger Posted at 9-7 02:33
Could you get a set of these to fit the screw size?[Image]
Scratch that you have no screw head
2022-9-7
DowntownRDB
DAFlys Posted at 9-7 01:16
Out of curiosity I weighed mine and it weighed 246g.  So they did have a little wiggle room left under the 249g mark.
2022-9-7
DAFlys
DowntownRDB Posted at 9-7 04:02
I guess they also need some "wiggle" room for manufacturing deviations too.
2022-9-8
Bashy
I believe that the Mini 3 is actually about 247 or 248g, that's why i said about the removable props would make it weigh more as it would need to add the base for each prop.
2022-9-8
DAFlys
Bashy Posted at 9-8 03:41
Well there was this test at 245g.
2022-9-8
DAFlys
Have you had any luck with those?  I had a set and they didnt work on regular screws so I ended up binning it.
2022-9-8
Bashy
DAFlys Posted at 9-8 04:05
[view_image]
I am sure all the videos i saw that it varied from about 247 to 247g which little to no room, this is the 1st one I've seen this low. As to why they all vary, has to be the scales and i wouldnt put my life on luggage scales accuracy either I have a set of micro scales, I haven't weight it  as folks already have but i will have a look, although, they came from amazon or ebay and prob far from accurate lol
2022-9-8
DAFlys
Bashy Posted at 9-8 07:15
DowntownRDB weighed his at 246 grams.  The 245g picture was DroneXl.
2022-9-8
Bashy
DAFlys Posted at 9-8 07:21
As i suspected, my scales said 221g lol I just spent 10 minutes trying to calibrate them to the weight of a bag of crisps, 22g that way the would only be a couple of grams out as it would only allow a calibration of 20g, then put on the Mini 3 and it came in at 116g lol so i calibrated to a can of beans at 200g and the drone came in at 221g, so I've given up, without a proper calibration weight its a dead end game
This guys came in at 249
Gavins came in at 248
2022-9-8
Bashy
Heres another thats in at 249 or 250g, they all prob weight the same, it will deffo be the scales but the question is, which is the correct weight lol
2022-9-8
DAFlys
Bashy Posted at 9-8 07:54
https://www.youtube.com/watch?v=mJt50u1Vj1g
Well I have some proper scales for light weight measurements,  mostly used for herbs and spices but on mine it comes out at 249.0 exactly and its in 0.1g increments unlike kitchen scales which are often 5grams.
So perhaps that weight is wrong,  but that would mean any filter over 1.1grams would make the drone illegal.
2022-9-8
DAFlys
Dodgey that they all use kitchen scales, I need to get out my special scales for this and give it a go.
2022-9-8
Mobilehomer
Flight distance : 18150351 ft
The problem is that DJI uses thread locker. The Mini and Mini 2 needed it because of the barely adequate thread engagement. The Mini 3 really does not need it because of  the full engagement. Or a much less aggressive type.
2022-9-8
DowntownRDB
DAFlys Posted at 9-8 00:34
I'm sure the components they buy from different manufacturers have a slight weight difference also.  I still really like the portability of the sub 249G drones.
2022-9-8
Beta5K
Flight distance : 196880 ft
Mine weighed in at 248g, but my scale isn't calibrated so I guess its more of an estimate.
2022-9-8
Bashy
DAFlys Posted at 9-8 08:32
Not sure about that, but i would trust kitchen scales more than luggage ones though.
I am surprised you haven't weighed yours already, especially when there are so many different weights going around. My El Cheapo jeweller's scales are just completely useless until i can get a calibrated weight and even then, I'm not sure i have any faith but i will order a weight off amazon and see what happens.
2022-9-8
DAFlys
DowntownRDB Posted at 9-8 10:17
I weighted mine at exactly 249grams with scales that have 0.1g accuracy.
2022-9-9
DowntownRDB
DAFlys Posted at 9-9 01:13
Mine was weighed at a Gold and Gem store that buys and sells gold so there scale is calibrated and re-certified quarterly.  Mine weighed 246G so I guess I got the runt of the litter so to speak.
2022-9-9
DAFlys
DowntownRDB Posted at 9-9 03:36
At 246g you should enjoy slightly loner flight times
I used my "special" scales. they are so sensitive you can change the weight of something just by blowing on it.
2022-9-9
DowntownRDB
DAFlys Posted at 9-9 03:46
Dang that is one sensitive scale.
2022-9-9
djiuser_7AmZwFtwsNLk
wanted to change 3 of the propellers from my DJI MINI 3 PRO for the first time as they had some wear and since I had 4 new propellers, why not? To my surprise ALL 3 screws were very tight! One was impossible to unscrew. I didn’t want to send it in for a screw that’s stuck. That’s ridiculous, I tought, so I forced it. The plastic thread broke off completely, with the screw in it.
2022-9-10
fansb05bb589
Flight distance : 325725 ft
I had same problem. Needed to replace one broken propeller and stripped the thread. Had to send it in to DJI just because of that! Really poor design, really poor screwdriver. I even bought a better screwdriver and still had problems removing the rest of the props. Not sure what the solution is but the situation is unsatisfactory.
2022-9-16
ficone67
Flight distance : 43773 ft
Switzerland
I have  the same issue with one head of the screw broke off and the rest of the screw remaining in the thread. I don't have any care assurance, but in my opinion the whole thing is a weak point/ bad development and it should be repaired on warranty. Somebody here who DJI accepted to repair on warranty?
2022-11-17
Marc00
ficone67 Posted at 11-17 12:03
To anyone coming across this thread.
I sent my drone to DJI, after the initial review they wanted me to pay for the cost of parts and labor. I talked to support and told them that the issue is due to the faulty screw and excessive use of adhesive and after taking a second look they covered it under warranty and actually sent me a brand new drone which I didn't expect.
2022-11-17
TonyPHX
Flight distance : 11229610 ft
You busted it.  Send it in!
2022-11-20
12Next >
