Where are the hyperlaspe waypoints saved?
831 2 2022-9-12
Vitruvius
Flight distance : 22556 ft
Hello. I am wondering where the Hyperlapse waypoints information is saved. I want to fly the same path a few times over a few months. Does this disappear if I clear my cache or switch tablets? Hope the missions are saved with my DJI account, not on the iPad since I need to clear the cache periodically because it takes up so much memory.
Thanks
2022-9-12
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The task library function is added in Hyperlapse. Tap the red box as shown in Figure 1 to save the current track routes or call up previous saved track routes. Select previous tasks and swipe to the left to bring up the option to delete the task.
1. The aircraft takes photos on a flight path of up to 45 waypoints.
2. There is no limit on the quantity of previous saved tasks.
3. Uninstall the app will delete the task library.
4. The task library cannot be exported.
5. The task library can be used when switching between models in the app on the same mobile phone.
6. The task library can be used when switching between accounts in the app on the same mobile phone.
Hope this helps. Thank you for your valued support.
2022-9-12
Vitruvius
Thanks for the reply. So the tasks are saved to the device which means that I will lose them if I change devices. Will they be deleted if I clear the cache on the device?
Thanks
2022-9-13
