Cable Pack
1484 8 2014-12-3
LIPHANTOM
Does anyone know if there is a cable pack available for the Phantom?
I had a crash a while back when I first got the phantom and when it hit the ground the camera support bolt broke free (As it was supposed to I guess) and the camera plugs yanked from the bird.    One of the cables does not plug in with a snap it just inserts.  The other for some weird reason snaps in. I think wasn't thought through since once the camera pulled down and reached the limit of the length of the cable it pulled the wires from the plug instead of simply disconnecting like the other.   I was able to "Fix" it with some effort but I don't fully trust it.   Without this cable plugged in I cant control the camera and I get no telemetry.
Has anyone else experienced this and is there a cable pack available for purchase?   Any help is appreciated.
Thanks
2014-12-3
Tony
Flight distance : 2856060 ft
Depends on which cable you need. A quick google search yielded this result:
https://www.google.com/?gws_rd=s ... ision%2B+cable+pack
or there's this one:
http://www.ebay.com/itm/like/111525649415?lpid=82
2014-12-3
LIPHANTOM
Tony@CVP Posted at 2014-12-4 00:24
https://www.google.com/? ...
Thank god not the ribbon cable.   There are two cables that decent from the bird and insert into the camera.   Its the smaller cable.  5 pin I believe.  The one that clips in.   Like I said it controls the pan of the camera and when unplugged I get no telemetry data.
2014-12-3
Tony
LIPHANTOM Posted at 2014-12-4 00:28
Thank god not the ribbon cable.   There are two cables that decent from the bird and insert into t ...
And it's not one of these?
http://www.amain.com/dji-phantom ... a3wm0YJYaAo7Z8P8HAQ
2014-12-3
LIPHANTOM
Tony@CVP Posted at 2014-12-4 00:36
http://www.amain.com/dji-phantom-2-vision-cable-pack/p362334?utm_source ...
Ahh!  It does look like it would be one of those.   I guess I should have searched harder before I posted.   I figured with all the talk about how hard it is to get parts for these things that it wouldn't be easily available.
Thank you for putting me on the right path.
Jim
2014-12-3
Tony
LIPHANTOM Posted at 2014-12-4 00:44
Ahh!  It does look like it would be one of those.   I guess I should have searched harder before I ...
No worries, we are all here to help!
2014-12-3
LIPHANTOM
Tony@CVP Posted at 2014-12-4 00:56
Thanks.  Do you have any experience with purchasing the from site you linked last?
2014-12-3
Tony
No, none. But you can find the cable packs at many other sites.
2014-12-3
Tony
http://www.uavdirect.com/DJI-Pha ... -p/djisp-p2v-cp.htm
2014-12-3
