Avata Won't Land
4716 31 2022-9-20
Jo060
Flight distance : 2513104 ft
I'm not sure if I'm missing something but my Avata won't land without forcing it.
I'll press the lock button to initiate a landing, it'll lower towards the ground but will never land. The goggles indicate that it's initiating a landing with the appropriate beeping tone, but it never will. I left it in the landing state for nearly 5 minutes with no luck.  I have to force land by holding the brake button in order to land.
I've tried different ground types from tile, grass, cement, and carpet. There is full connection to include GPS.
Any ideas?
2022-9-20
Jo060
I reached out to DJI who said the Avata does not auto land. Interesting.
2022-9-20
DJI Stephen
Hello there Jo060. I am sorry for the trouble this has caused and thank you for reaching out. May we please know if you have received any error message / error codes on the DJI Fly application when this is happening and may we also please know before having this issue did your DJI Avata had a hard landing or a crash before? Thank you.
2022-9-20
Jo060
DJI Stephen Posted at 9-20 21:35
No error codes or hard landings.
The person on the online chat said it doesn't auto land, is that accurate?
2022-9-21
WernerD
Flight distance : 350837 ft
Austria
Of course it does auto-land.
Currently I steer the drone manually to the home point, let it hover 1m above ground and then press the red lock button for a longer time. It initiates landing and turns off the motors after touchdown.
Having said that, I do have still some open questions myself:
  • Another way to land is to push the stick/motioncontroller all townward into that additional icon. Is that correct? Must test it also.
  • When initiating RTH close to the home point, does it land where it is right now or exactly at the home point. All other drone have a 5m(?) limit. Within they land immediately, outside they perform a RTH.
  • How would you land if it must be exactly at the take off position as this is the only spot in the vincinity?
2022-9-21
DJI Wanda
Jo060 Posted at 9-21 01:18
Hello, there. Forced landing is required as the DJI Avata does not support auto landing. When using DJI Motion Controller to control the drone to land, a prompt stating that “the aircraft will be forced to land, please confirm the flight environment” will be shown.
2022-9-21
WernerD
Austria
Maybe I use the term "auto-landing" wrong?
https://dl.djicdn.com/downloads/DJI_Avata/20220825/DJI_Avata_User_Manual-EN.pdf
Page 50 of the manual says:
Lock Button
Press twice to start the motors of the aircraft.
Press and hold to make the aircraft take off automatically, ascend to approximately 1.2 m, and hover.
Press and hold while the aircraft is hovering to land it automatically and stop the motors.
Press once to cancel Low Battery RTH when the countdown appears in the goggles.
2022-9-21
Jo060
WernerD Posted at 9-21 01:54
I agree. Something doesn't make sense.
2022-9-21
RichfromHowellNJ
Flight distance : 508255 ft
Maybe another firmware update for the controller?  I'm sure you made sure that all your firmware is up to date.  Any chance you could try taking off and landing from/onto a landing pad?  Just to see if you get different results.
2022-9-21
Jo060
RichfromHowellNJ Posted at 9-21 02:13
Possibly.
All firmware is up to date.
I don't have a specific landing pad but have tried multiple services, all of which my other drones land without issue.
2022-9-21
RichfromHowellNJ
Jo060 Posted at 9-21 02:15
Possibly.
The only reason why I was suggesting "trying" a landing pad is maybe it has something to do with the downward sensor.  Maybe it is not sensing a safe place to land.  Just a thought.
2022-9-21
Jo060
RichfromHowellNJ Posted at 9-21 02:47
That's definitely possible.
Does your Avata auto land?
2022-9-21
RichfromHowellNJ
Jo060 Posted at 9-21 02:48
Yes it does .... I find it is a 2 step process.  I have to "press & hold".  Then a message comes up to hold down the button and it will land.  But I'm using the motion controller.  My regular controller is a bit far away and won't get to it until a few months.  I'm wondering if it behaves differently with the traditional controller.  Next time I'm out flying with the motion controller, I'll check the DJI App to see if you can select it to land itself within the app/goggles.
2022-9-21
Jo060
RichfromHowellNJ Posted at 9-21 02:52
Very strange.
I'm using the motion controller too.
I've never looked, but is there some type of hard reset for the drone? Maybe that could be a fix.
2022-9-21
Jo060
I was able to get it to auto land.  I'm assuming I was initiating an auto land request at too low of an altitude. I raised the altitude to about 3 ft and it landed without issue.
Interesting that 2 different DJI reps said the Avata can NOT auto land.
2022-9-21
Jo060
DJI Wanda Posted at 9-21 01:44
Were you just guessing?
2022-9-21
DJI Wanda
Jo060 Posted at 9-21 04:13
Kindly know that the Auto Landing feature has a button like Auto Takeoff.
Take DJI Air2s for an example
2022-9-21
Jo060
DJI Wanda Posted at 9-21 04:40
[view_image]
OK, just curious. Previously you had mentioned the Avata doesn't have the auto land option.
2022-9-21
KLRSKIR
Flight distance : 28368625 ft
Jo060 Posted at 9-21 04:42
Technically it does not. You need to hold the lock button to initiate the landing, as Wanda posted above. Thus, it's not "automatic" like other DJI aircraft.
2022-9-21
Jo060
KLRSKIR Posted at 9-21 04:46
I suppose that's one way to look at it, however, the goggles display Autoland after depressing the lock button.
DJI Wanda mentioned it needed to be forced to land which is an entirely different option.
2022-9-21
KLRSKIR
Or, it will "auto-land" after it's "forced" to land.
2022-9-21
Jo060
KLRSKIR Posted at 9-21 05:15
Touche
2022-9-21
deeve
Flight distance : 72864 ft
I am only using the Motion Controller right now and have noticed that holding the Lock button down will land it most of the time. However, both a buddy and myself have had situations where the drone would not land using that process over aggregate concrete or pavement. The area was clear and had been used to take off and land previously, but for whatever reason there are times when it will not land. I forget the exact wording, but a message comes up to make sure the landing area is clear, which it is.  It would be nice to have the option to override warnings and  fully force land the Avata with the Motion Controller. Maybe there is, but I have not been able to figure it out.
Dave
2022-9-21
RGMGFitness
Flight distance : 233757 ft
@WernerD...Yes, you are 110% correct.  If using the 'DJI Motion Controller' (which I've been using for many flights now).  I'ts EXACTLY as you've stated above.....
Simply "Press and HOLD the LOCK button while the aircraft is hovering"  To have it hover in place just hit the BRAKE button 1st.  It should then AUTO-LAND!
Alternately, you can grab the drone (watch your fingers) on top and simply flip it over (personally..that's my go-to) simply because I've always done it that way with all my drones.
See this video as well...just jump to 15:20 in the video....again...PRESS & HOLD to LAND
2022-9-21
RGMGFitness
One thing to clarify with the AVATA as well.....You can fly with the 'DJI Remote Controller 2" or the "DJI Motion Controller".  So, always clarify which your using to assist with the troubleshooting.  If using the 'Controller 2" also what MODE your in (NORMAL MODE, SPORTS MODE, FULL MANUAL (ACRO) MODE).
2022-9-21
Jo060
RGMGFitness Posted at 9-21 05:45
It's all figured out.
It didn't like to auto land from its lowest allowed altitude. I had to raise it to approximately 3 ft for it to auto land.
2022-9-21
RGMGFitness
Jo060 Posted at 9-21 05:47
Glad you got it all figured out..
2022-9-21
WernerD
Austria
Just came back from a couple of flights. The Avata does support auto landing, it says so in the display.
  • When you hover and long-press the lock button, the display says "starting auto-land". So much about "does not support auto-land".
  • It did lower itself from 2m above ground to approx 0.5m and then stopped, display said that it cannot find a suitable landing position. I accept that. It was rocks next to water.
  • With another long press of the lock button, forced landing is initiated. It did land at that spot.
  • Tilting the stick all down allows the drone to descent vertically. But that stops at approx 0.3m above ground. So it is not suited for landing.
  • Triggered RTH and it flew back to the start point, did hover 1m above ground and display said it cannot find a spot to land safely. Same reason as above, fully understandable.
  • So I picked the drone from the air by hand - no problem. Much easier as with the Mini 3 as you can grab it from above. Will probably be my most used landing procedure.
2022-9-22
Jo060
WernerD Posted at 9-22 02:04
Yup, I was able to get it to auto land, now. It bit mkmd blowing that 2 DJI reps said it doesn't support it.
2022-9-22
djiuser_n1fe7CnT4xoL
Im having trouble auto landing and then im clicking lock 4 times when its .2m off the ground and it wont emergency stop rotors. Then i hold the drown and it goes frantic and wants to go everywhere then it stops. It does that all but one time where it auto landed but there is no rhyme or reason. Theres no way it should need a landing mat as it would have came with one then.
2023-12-24
D35Archangel
Flight distance : 291345 ft
Brunei
If the vision sensor cannot see the ground properly whether its dark or maybe uneven it will ask you to force to land if clear. In those cases, IF its clear, just hold the red button and it will land. Its usually vision sensor issue on dark ground.Another way is while the drone is hovering, hold the back of the battery from the top firmly and flip it upside down and the rotors will stop.
2023-12-24
Ok, i tried auto land from at least 1m up. No problem. I guess it needs a little bit of height to read.
2023-12-25
