Goggles 2
957 6 2022-9-24
djiuser_lwE3SRh9LWUl
Flight distance : 799698 ft
Goggles 2 :No martter what I do I can't see the bottom of the screen clearly . It is impossible to read the information along the bottom edge. If I move the bottom of the goggles away from my face then it becomes clear. This is dangerous and all of the safety information is not readable.do I have a defective pair ?
2022-9-24
JiminMorris
Flight distance : 230 ft
Have you tried adjusting and positioning the strap on the goggles at the back of your head?  This pulled the goggles up a little higher for me by moving the strap up a bit in back.  This way I got the whole image in focus...
2022-9-24
JiminMorris Posted at 9-24 18:13
I'll   give that a try thanks for the tip
2022-9-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Kindly please try to adjust the strap on your Goggles 2 until it secures your head and sees the screen clearly also as per Jimmin suggestion on post #2. If the issue persists, kindly please send us a short video showing the issue for us to check if there is some issue with the strap. Please keep us posted. Thank you for your valued support.
2022-9-24
HDPS
Flight distance : 44957 ft
not defective, poor design for bigger faces is my guess, got it today and have the same experience, now...I do have myopia and stigmatism, I just ordered a prescription lens and hope that will solve the problem. I also have the FPV goggles and use with my glasses on and love it...not impressed with the goggle 2 at all, the power socket is not tight on mine and it will come off very easy....will need thinker what I can do to prevent accidental disconnection
2022-9-24
djiuser_A3JQh8cEFwlj
Flight distance : 8842 ft
Switzerland
Goggles 2 are really good, Power socket fine on mine. But it is true that edges are harder to see and there should be additional face-rubber to comfortably adjust.
Can we customize the Home Screen to keep only essentials in the center? Battery, Distance to the ground, RC signal level.
3-2 11:32
DJI Paladin
djiuser_A3JQh8cEFwlj Posted at 3-2 11:32
Thank you for your response. Unfortunately, this function is currently not supported. We will gather this concern as a suggestion and will forward it to our relevant team for future consideration. We appreciate your understanding and support.
3-3 02:37
