Horizon not straight
4119 14 2022-9-25
Zwolsefoto
Flight distance : 112556 ft
I'm using a new DJI Mini 3 Pro drone
right from the start  i don't have a straight horizon the right side is higher then the left side
and some times when i start up the aircaft it a bit of a strange noise dissapears after a second
is there something wrong with the gimbal (it works well accept hte levelling of the horizon)
i calibrated the gimbal ,the aircraft and the RC controller but the problem remains
how to fix it (it looks bad special in the video's )
Horizon
Horizon
2022-9-25
Mavic57pro2
Flight distance : 3772247 ft
Maybe try calibrating the IMU of the drone ?
2022-9-25
DJI Stephen
Hello there Zwolsefoto. Thank you for reaching out and for giving out these information. May we please know before having this issue did your DJI Mini 3 Pro had a hard landing or a crash before for us to be able to isolate the issue? Thank you.
2022-9-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble. Can you please try to connect your drone to the DJI Assistant 2 software and please update/refresh the firmware to see if the issue persists? In addition, you may try to reset the gimbal settings under your Advance Gimbal settings then calibrate again the gimbal then check if the issue persists. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-9-25
PAROINA
Flight distance : 3279160 ft
I am on my 4th Mini 3 due to gimbal issues. 2 of them had a buzzing noise at startup. If that is what yours has, return it for another or send it to DJI for repair.
2022-9-25
Zwolsefoto
DJI Paladin Posted at 9-25 19:24
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
I tried everything calibrating everything
the only way to keep the horizon straight is manually set it but when I started up the next time I have to
do this again
very annoying
With friendly regards
2022-9-26
Zwolsefoto
PAROINA Posted at 9-25 20:19
That's the same here
but the buzzing noise is n't everytime
So I think there is something wrong with the gimbal
with friendly regards
2022-9-26
Zwolsefoto
DJI Stephen Posted at 9-25 18:50
No
Nothing it was from the beginning the issue
2022-9-26
DJI Stephen
Zwolsefoto Posted at 9-26 00:12
No
Hi there Zwolsefoto. Thank you for the reply and for this additional information. Since we are having this issue with your DJI Mini 3 Pro. It would be best to contact our DJI support team at https://www.dji.com/support for further assistance. We will do our best to help and give out the best resolution for this issue. Again I am sorry and thank you.
2022-9-26
Zwolsefoto
Well contacted DJI support and the only thing they could do is send it in for repair and that means that I will at least won't have a drone
for my work and I use it almost every day
Warrenty goes through the reseller and that means that I will mis the drone for two weeks
not a service with I'm use to due to the warranty
2022-9-26
djiuser_YC0dKNR69MZ3
Flight distance : 424767 ft
Zwolsefoto Posted at 2022-9-26 00:08
do this again
https://youtu.be/rn4fOXYMIT4
2023-5-31
Ranjan
India
djiuser_YC0dKNR69MZ3 Posted at 5-31 09:03
Thanks for sharing this
2023-5-31
djiuser_WnOBeKL1zcOm
Finland
Zwolsefoto Posted at 2022-9-26 07:32
When you calibrated the gimbal was the drone on a LEVEL surface?
2023-11-24
Zwolsefoto
djiuser_WnOBeKL1zcOm Posted at 11-24 10:35
yes
but was not the problem DJI has a great service and this was a common issue so they replaced the drone
Problem solved
2023-11-25
DJI Tony
Zwolsefoto Posted at 11-25 10:53
yes
Problem solved
We're glad you already got a replacement. You can always reach out to us if you need further assistance. Thank you for your great support.
2023-12-8
