Max SDMicro Card Supported by DJI RC?
753 21 2022-10-1
SammyUGA
What is the max size microsd card supported by the DJI RC?
2022-10-1
DowntownRDB
Flight distance : 1722 ft
I've used a 512GB card in the RC without issue.  However, it is a bit of overkill just to screen record.  Best to put that size card in the drone.
2022-10-2
DJI Wanda
Hello, there. You may refer to the recommended list through this link:  https://www.dji.com/rc/specs
2022-10-2
SammyUGA
DJI Wanda Posted at 10-2 18:30
Many thanks!  I assume from this that 512 is max?  Also, any formatting required before I use?  Thanks again.
2022-10-2
SammyUGA
DowntownRDB Posted at 10-2 02:32
Thanks. I wasn’t even aware the RC had an Sd slot. So which does what?  Drone records and remote takes stills?  Thanks again.
2022-10-2
DowntownRDB
SammyUGA Posted at 10-2 20:22
The drone can record videos/photos to the inserted SD Card.  Best to format the card while it is in the drone by using the DJI Fly App.  The new DJI RC can screen record or screen shot if you have an SD Card in it.
2022-10-3
DJI Wanda
SammyUGA Posted at 10-2 20:07
Thanks for your reply. All the SD cards on the recommended list have been tested.  We can not guarantee the compatibility of other SD cards. You may format the SD card via App or on the computer if needed.
2022-10-3
SammyUGA
DowntownRDB Posted at 10-3 01:57
Thanks very much. So when I press record or still photo button on my DJI RC am I recording on the card in the drone or onboard the RC?  Trying to figure out where to put the larger SD card.
2022-10-4
SammyUGA
So if I have cards in both the drone and the remote when I press record on my RC remote am I recording on the card in the drone or the RC?  Or does it make no sense to have cards on both drone andvRC?
2022-10-4
DowntownRDB
SammyUGA Posted at 10-4 19:44
When you press the still or record button you are recording to the drone so best to put largest card in the drone.
2022-10-5
DowntownRDB
SammyUGA Posted at 10-4 19:48
The card in the RC is only used when you go into the Fly App settings and turn on "screen recording".
2022-10-5
SammyUGA
DowntownRDB Posted at 10-5 04:00
Many thanks!
2022-10-6
SammyUGA
DowntownRDB Posted at 10-5 04:01
Many thanks!
2022-10-6
SammyUGA
Many thanks!
2022-10-6
SammyUGA
Many thanks!
2022-10-6
SammyUGA
Thank you.
2022-10-6
DowntownRDB
You're welcome.
2022-10-7
DowntownRDB
You're welcome.
2022-10-7
DowntownRDB
You're welcome.
2022-10-7
DowntownRDB
My pleasure.
2022-10-7
George 13
Hi, do you need to use 2 micro sd cards or is one sufficient in the drone or in the remote please.
4-18 06:38
DJI Tony
George 13 Posted at 4-18 06:38
Thank you for reaching out. It is recommended to have a MicroSD Card in the drone and RC. Here are the reasons why you need a microSD card for the remote controller:
1. It is for caching videos (the current firmware version does not support photo caching).
(Note: Videos cannot be cached if a microSD card is not mounted. Meanwhile, you can only preview low-definition files after tapping the Playback icon on the screen of DJI RC when the aircraft is powered on. If the aircraft is powered off, no files can be viewed through the remote controller, because the files are transmitted from the aircraft in real-time.)
2. It is for screen capture and recording.
(The screenshot and screen recording functions are only available after installing a microSD card. When the microSD card is not installed, a prompt will appear stating “Install microSD card”).
3. When the microSD card is not inserted, it is unable to copy internal storage files to the microSD card [Currently, the internal storage cannot be accessed by computers or mobile devices.]
Hope this helps. Thank you for your support.
4-21 22:06
