remote controllers
djiguy001
Hi,
Assuming these are out of warranty - but can I still get them fixed?
1 phantom 3 (I think both are adv) - the remote doesn't seem to work/connect to the ipad (for the image). Seems to connect to the drone - just no image when plugged into the ipad. How can I fix this? Also - one attenae is slightly broken (not broken off, the wire is still connected, just broken).
Other phantom 3 - remote/attenae is broken. (Unit still works fine, I just have to use duct tape to hold attenaea there. Was thinking of using crazy glue, but open to other suggestions). How much would it be just to fix that?
Also - I'd like the versions (firmware) not to be tampered with (because sometimes it breaks things).
Thanks!
2022-10-10
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your understanding and support.
2022-10-10
