Montfrooij
Flight distance : 2560453 ft
There is still a couple of things to take into consideration.
1. Faster shutterspeeds will lead to less stuttering.
2. The 180 degree rule will help prevent stuttering too
3. If you want to shoot artificial lighting, it is best to stick to the 'region' you are in. So for PAL area, the frequency of the grid can cause flickering in artificial lighting if you don't align with that (25-50fps). If you are in NTSC area, 30 or 60 ar best.
4. If you want to combine footage from other camera's, make sure they are shot in the same framerate (or half / double). So 30-60 OR 25-50. Otherwise you will get frame skipping, which looks aweful.
Now this might not be relevant if you 'just' want to shoot some drone footage, but those 4 things are quite important if you
Some 'claim' that 24fps equals cinematic footage, but 24fps is the slowest framerate you can get away with and it is the hardest to shoot in because there are such big gaps between the frames.
You can get cinematic looking footage at any shutterspeed. If you know what you are doing.
For me it is 50fps 2.7K on the Mini 2. So I can slow my footage down if I want to (for extra smooth movement).
And I don't need 4K myself.
