Mapping with video
1056 15 2022-11-25
ReppocMike
Flight distance : 1627667 ft
Finland
Hi!
Can I use video recording during Mapping mission?
We found only photo option but SAR operations video is better.
We use this video for double check.
2022-11-25
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi, have you tried waypoint mode ? Not mapping
2022-11-25
ReppocMike
Finland
LV_Forestry Posted at 11-25 09:52
Yes It works. but its not the same. Route you made by hand is not same. Mapping road is the point Im looking for. Same distance all directions.
2022-11-25
LV_Forestry
Latvia
ReppocMike Posted at 11-25 09:59
Then you can try to prepare a mapping missing on UGCS. It will draw a regular path. Load it as KMZ/KML in waypoints mode, and that's it !
2022-11-25
ReppocMike
Finland
LV_Forestry Posted at 11-25 10:01
Yes you Can do It that way, but the point is to use Dji App and Dji controller. It is only small add to Pilot2 app. :j
2022-11-25
LV_Forestry
Latvia
You still use DJI Pilot2. Just generate the KMZ/KML on a laptop. I transfer via SD card when i have time, when its emergency i transfer via USB cable.
2022-11-25
LV_Forestry
Latvia
ReppocMike Posted at 11-25 10:09
There is also a free extension module in QGIS named Flight Planner
2022-11-25
ReppocMike
Finland
LV_Forestry Posted at 11-25 10:13
Ok! Can you send me a link for that.
2022-11-25
LV_Forestry
Latvia
ReppocMike Posted at 11-25 10:17
In QGIS you go to Extension/Manage extension in the search bar you type Flight Planner -> click on "instal plugin"
https://www.qgis.org/en/site/
2022-11-25
ReppocMike
Finland
LV_Forestry Posted at 11-25 10:25
Hi!
This is interesting but way too slow method to make flight path
I still wait for answer to Dji for this issue.
2022-11-25
LV_Forestry
Latvia
UGCS is the fastest. Not sure someone from DJI will answer.
2022-11-25
TerrainDrop
Map Pilot Pro has a video recording mode while doing mapping data collection.
2022-11-26
ReppocMike
Finland
TerrainDrop Posted at 11-26 08:34
Ok! How It work?
2022-11-26
TerrainDrop
We have used it for some of our testing. I think all you have to do is select Video in the Data Capture Format in the settings and it records video while on the designed flight path.
2022-11-26
ReppocMike
Finland
Ok I found this one. We need to test this. But still it is better if it work direct to PilotApp2.
2022-11-27
LV_Forestry
Latvia
ReppocMike Posted at 11-27 06:04
https://www.youtube.com/watch?v=KjWKdfEc1j4
I proceed like that too. I bet you will have success with this procedure
2022-11-27
