Max recording length per file?
2819 9 2022-11-28
Schaffner
Hi,
I now have a Mavic 3 Classic.  I'm recording video at 4k 30 fps in normal mode.  The Micro SD card is a 128 GB SanDisk Extreme Plus.  When I record it will create an MP4 file that's 3 minutes 47 seconds long, and then create another file for the next 3 minutes and 47 seconds, and so on.  How come it's doing this?  Can't it create bigger files?  I formatted it on the Mavic 3 Classic and the filesystem is exFAT.  It should be able to create files bigger than 4 GB.
Jim
2022-11-28
Labroides
Flight distance : 9991457 ft
New Zealand
If you shoot at a lower resolution or frame rate it will last a longer time.
The limit is on the file size.
That's just the way it is.
2022-11-28
DJI Tony
Hi there, Schaffner. Thank you for reaching out, and apologies for any inconvenience caused. Captain Labroides is correct. Please note that the maximum capacity of a single file will not exceed 4 GB, and the resolution setting plays the most vital role. Additionally, due to the limitation of the SD card file system, and to protect the safety of your footage, the video will be automatically split when the size of the video reaches 4 GB. Your understanding is highly appreciated. Happy flying!
2022-11-28
Captgeo
Flight distance : 1195472 ft
Why though?  I use a Insta360 oneRS regularly and it can do a single file of greater length.  Is it just DJI limiting this?
2023-9-28
Johnnokomis
Flight distance : 13424032 ft
Captgeo Posted at 9-28 15:22
4GB is a size limit on FAT32 file systems. It's not DJI. If you have files bigger than that on an SD card then it's formatted in exFAT more than likely.
2023-9-28
Captgeo
Johnnokomis Posted at 9-28 16:08
The card in my M3 is formatted in exFAT...   and still the limit.  HAS to be DJI
2023-9-28
Labroides
It's always been this way on DJI equipment.
There is no way around the filesize limit.
If you want a longer video, you would have to reduce the resolution you shoot at.
2023-9-28
CloudVisual
Flight distance : 97545420 ft
Most likely the DJI drones run on 32 bit architecture. It's not something I do (film long videos), but I did assume that the cards these days being formatted by the drone to ExFat made me believe that the 4GB file limit no longer existed.
Nevertheless, the separate videos are seamless, so there's no lost data. Just drop the clips, in order, into a video editor and you have one long video.
2023-9-30
fans2ddd763f
Labroides Posted at 2023-9-28 20:10
Not true, my DJI Phantom 4 pro shoots video on sd cards until I stop recording.
5-9 09:57
Labroides
fans2ddd763f Posted at 5-9 09:57
What I said is 100% true.
Time isn't what matters, it's the file size.
Check to see if your files are >3.8 GB.
Perhaps you are shooting at a lower resolution than $k.
If so that would allow a longer file and still be <3.8GB.
5-10 00:38
