M300 and P1, Low mapping speed problem
1393 1 2022-11-29
Martin Skymaps
Slovakia
Hello,
we finally updated our M300 to the newest firmware (released 24. 11. 2022). Mapping speed after the update is much lower than in previous firmware. We are able to fly 6.5 m/s in 80m AGL with 70%/70% overlaps. It means we are able to capture photo every 2,5 s (with P1), that is extremely low!!!
We are selling M300 as a platform for agricultural mapping of the fields for our clients which are using product called Cultiwise (cultiwise.com). It is absolutely inacceptable if we are 50% slower in mapping after the update. Our clients are not accpeting that.
1: Is there any chance to downgrade the software?
2: Will be there a new update which is going to fix the mapping speed?
Thank you and best regards,
Martin
2022-11-29
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
It seems DJI mess with the minimum interval. Add custom camera and try this :
8192px 5460px
35.9mm 24.0mm
35.0mm
1.0s
You could also try to downgrade via DJI Assistant 2
2022-11-29
