FPVTrendz
Flight distance : 1241020 ft
Are you bending your wrist or twisting your wrist? You are supposed to twist your wrist left and right not bend it just in case that's what you are doing.
Also, just to rule out one other thing. When doing this, are you looking through the goggles or are you looking at the drone while it's facing you? Because if it's the goggles, then you must be twisting your wrist incorrectly. If you are visually looking at the drone and its camera is facing you, then that's normal for it to turn right with left movement and vice versa. I'm just trying to look at all angles here that may be wrong since we can't see what you are doing. |
