Geo_Drone
Flight distance : 2733720 ft
Romania
SpikeHuelva Posted at 1-2 02:25
Thanks for your reply. I have uploaded the video to Google Drive for you to look at rather than the render from Youtube. I have learnt a lot from this post and now have several things to try out. I am delighted with the drone.....I just want to make sure I get the best out of it that I can. Thanks for looking. Mark
What you have is an user error both in recording and in editing.
1. The movement is far too fast for this sensor...a 90 degrees movement of gimbal should be made in full 22 seconds in order to have a smooth feeling. Does not matter you use 60fps or 24fps, the difference between 24 and 60 is only 5 seconds, so at 60 fps you can make a 90 degree movement in only 17 seconds versus 22 seconds in 24fps (so is not HALF TIME, ok?).
2. You have 2 different footage there...so in Premiere Pro or Davinci you need to REINTERPRET all footage on same FPS. After this, any change in speed must be made using OPTICAL FLOW option, as you will have skipped frames. Learn how the video is made, how FPS are composed and what is the Primary Frame in each set of FPS...(encoding of frames). Will help you.
3. You need to use a universal FPS in order to be without visible skips...this is why many use 24fps, as all TV's have Movie Mode with 24FPS adapted and Anti-Jitter for it. I advice you to use a base of 30FPS at start, in order to have room for slow-downs to 24fps and in editing DO NOT use SPEED but FPS REINTERPRETATION at beginning...this will prevent the Primary frame to be reencoded twice and your video to look like a blinking man looking at it.
Cheers. |
