M30 Drop Pins on Map
2745 6 2023-1-3
AIRWORKS.
Flight distance : 5872635 ft
Does anyone know if its possible to export a map from pins dropped in the field?
2023-1-3
LV_Forestry
Flight distance : 4726654 ft
Latvia
What do you mean by pins dropped in the field?
2023-1-3
AIRWORKS.
Sorry ill explain in more detail, I am working with the water department, we are inspecting flooding in areas near a rising river and we put pins down using the drop pion function in the M30 and I assumed that these are saved somewhere and i could output a map for the crews to go and inspect and fix problems but i cannot work out how to send them the map?
2023-1-3
LV_Forestry
Latvia
AIRWORKS. Posted at 1-3 12:26
I see
https://enterprise-insights.dji. ... ngefinder-pinpoints
2023-1-3
LV_Forestry
Latvia
They must be saved somewhere on the radio in WGS84 format, openable in QGIS.
2023-1-3
AIRWORKS.
Thanks again for your help and time, i looked everywhere and couldn't even find any info LV very much appreciated
2023-1-3
Cudori
Flight distance : 31404 ft
hey,
i found this thread today. do you still need the info on exporting pinpoints?
If so still here is the solution, if not here is the solution for others. ;)
Go to the camera menu. Long press L3. check all pins. Then the button in the upper left corner and save as kml.
in this file are all files with his colour and you can import it for example in QGIS
2023-4-16
