When will there be a new firmware version to be able to connect Canon r6mk2?
Canon 6d MK2 - DJI detects the camera but won't connect
The cable connection does not work either on both camera.
Can someone write me detailed instructions on how to connect the camera with DJi RS3 mini?
DJI Mindy Posted at 1-28 02:12
Hi there, you can refer to the tutorial and the setup method below. https://www.dji.com/support/compatibility/rs-3-mini/6d2
https://www.youtube.com/watch?v=g-Yw6jqdIoE
Sorry for the inconvenience, the compatibility list on the official website is currently under maintenance, some models cannot be queried temporarily, and will be restored after maintenance. Thanks for your understanding.
Bonjour,
Toujours aucune mise à jour pour que le Canon ROS R6 Mark II puisse se connecter en bluetooth avec le RS3 alors que le R6 II est sorti depuis maintenant 9 mois.
DJI, si on achète un produit comme le RS3 c'est pour qu'il puisse est connectable avec les boitiers photos qui sortent en suivant.
Une mise à jour en 2023 ???
In the meantime the EOS R6m2 is listed on the RS3 Mini Compatibility List - using the Camera Control Cable still does not work. Using the same Cable with a EOS R5 works fine (Connection Message on the gimbal screen, front dial can be used as setup in the menu)
