CNC Body protection
1053 4 2023-2-14
freedom2000
Flight distance : 519747 ft
Hi all,
Do you have any feeback on these body protections ?
aliexpress protections avata
Are they usefull or scrap ?
What about the extra weight ?
Thanks
2023-2-14
DowntownRDB
Flight distance : 1722 ft
They look like they are quite well engineered to help protect the camera.  Probably weigh next to nothing.
2023-2-15
freedom2000
I have started to make one in PET (plastic bottle). It's strong and light.
I designed it "flat" then used hotgun to bend it so that it touches the bottom plate and shouldn't block the camera field of view.
2023-2-15
freedom2000
I finished my camera protection. And it works really well.
  • Barely visible when camera is tilted full down (as we already can see the avata's frame!)
  • Unvisible in flight even when camera is tilted up.
Finally I prefer this light (7g) 3D printed solution as it may break during a shock rather than CNC aluminium protections which will never break but may destroy the frame instead...
You can find it on my thingiverse page : https://www.thingiverse.com/thing:5882980
  • Printed with PET filament
  • Bended with hotgun (when not in place to prevent destroying the camera...)
  • fixed with 10mm long M2 screws
2023-2-28
freedom2000
Just an update after a quite big crash (battery ejection after frontal crash on the ground).
I can say that it works as expected. protection has broken but no wear on the drone itself ! Just needed to reprint the protection !
It's simply working sooo well !
2023-7-21
