Arri Alexa 35 on Ronin 2
3237 4 2023-2-28
The4DGuru
What cable is best to power a Arri Alexa 35 on a Ronin 2?
2023-2-28
DJI Wanda
Hello, there. Thanks for your inquiry. Would you please confirm the power requirements of the camera?
The power cable and user guide can be viewed here:
https://store.dji.com/product/ronin-2-own-power-cable
2023-3-1
The4DGuru
The Camera is 24 volts
2023-3-1
djiuser_Oqy99oMkihtv
I see you didn't get very helpful replies so far ^^
If it's still relevant for you, there is a cable manufactured by Ignite Digi.
As the Gimbal itself can only output 12 Volts while the Alexa obviously needs the full 24 Volts, the only all-in-one solution is using the Ronins output up at the batteries using the Ignite cable. Only downside is the cable running for outsider the gimbal into the rig. As its pretty flexible that's not much of a Problem in regular use.
Another downside might be a lot more battery changes for the Ronin then you're used to. The A35 draws much more power then your usual Mini / Mini LF.
If you own both a Ronin 2 and the Alexa, it might be worth it to look into the self-made modifications that are out there as well.
Those enable you to actually place a 24V output inside the rig!
Other than that I also managed to squeeze the A35 into the Ronin with a B-Mount battery still mounted.
Probably only works with heavy / long enough lenses, but absolutely not fully of the table!
Hope I could help!
2023-3-20
The4DGuru
djiuser_Oqy99oMkihtv Posted at 3-20 11:14
Thank You, very helpful indeed!
2023-3-21
