Battery failure and crash to concrete from 30 ft
776 1 2023-3-5
fans62d29254
While I was climbing from a takeoff, I noticed only "Critical XXX" (unsure what the exact alert was) and then the Spark crashed onto a concrete driveway from about 30 feet. I suspect the battery had a catastrophic failure that did not allow me time to land. Two propellers broke and the gimbal popped out of its retaining ring. After changing batteries, installing two new propellers and reinserting the camera gimbal and then calibrating the IMU, the drone flew and the camera worked, but it did not recognize the SD card and I could not capture images or video. What is the recommended repair service? Is it worth repairing?
2023-3-5
Hi there, we are sorry for the crash. We recommend that you start a case through the link below and send the drone for diagnosis and repair. https://repair.dji.com/repair/index?site=brandsite&from=nav After the damage assessment, our team will send you a quotation accordingly. You may also refer to the link below. https://repair.dji.com/repair/price-inquiry
2023-3-6
