DJI DL 17-28mm lens auto focus not working
3720 16 2023-3-18
DiddyDarnell
I'm having an issue with getting the auto focus to work at all the focal lengths of the new DJI 17-28mm zoom lens on the Ronin 4D.
When I set the lens to 17mm and auto calibrate, AF works great at the 17mm focal length, but as soon as I switch to any other focal length the auto focus and manual focus are off.
Is anyone having issues with this new lens? I've updated the camera to the latest firmware and still have this issue.
Thank you for any help.
-PD
2023-3-18
fans8ccfbbe4
I’m also having issues AF doesn’t work well and in MF the lens skips focus when zooming
2023-3-28
djiuser_2FC3ZZeU1O7I
Same here with Sony lens
2023-4-24
djiuser_bcQ4mUdn0QJq
I have to do automatic calibration every time I change the focal length of the 17-28.
Any solution?
2023-4-26
I read in another thread that the dji dl 50 mm lens does not need autocalibration. It is not the case with the 17-28 lens, I have to do the calibration every time for each focal length otherwise the autofocus does not work and the mapping with Lidar does not communicate with the lens. Does anyone have a different behavior with this lens?
2023-5-2
fans2c11a6d8
djiuser_bcQ4mUdn0QJq Posted at 4-26 09:44
Any solution?
same for me
2023-5-13
MarshallZhang
Hi, I wonder did the newest firmware(12th, May, 2023) fix your issue? Thanks in advance.
2023-5-16
fans2c11a6d8
MarshallZhang Posted at 5-16 20:53
not for me, everything updated and will only autofocus at one focal length
2023-5-17
In my case the last firmware available to update is 1.04.0303 dated 2023-04-23.
In any case it doesn't solved the issue.
Autocalibration every time I change the focal length !!!
2023-5-22
djiuser_xMULhJsPbANU
same issue here
2023-5-26
fansd8781149
Flight distance : 31145 ft
Russia
i wonted to buy this lens. Now i don't. it terrible recalibrate every time. shame.
2023-6-9
ddecker
Same issue here...
2023-6-19
tom.flybyap
Flight distance : 6031063 ft
Same issue here. Pretty frustrating for the run and gun style shooting that the 4D is otherwise perfect for. At least give us an option to shortcut the calibration process until DJI fixes the issue.
Weirdly I shoot with a buddy a lot that has a 4D as well on all the same firmware and he doesn’t have the calibration issue.
2023-6-28
fansc207910d
Hello, after doing an online chat with DJI this is the fix they provided me:
"Enter the menu of the DJI Ronin 4D High-Bright Main Monitor, and set “Lens Calibration Information” to “NA” on the “Lens - Calibration” page to use DJI Ronin 4D without calibration."
I asked for clarification, they said to not use auto calibration or manual and to always select NA and the issue should be "resolved".
Might not be the best answer but at least it's something.
2023-7-13
nikemerlino
fansc207910d Posted at 7-13 06:05
It works! Solved,
Thanks
2023-7-26
fansd8781149
Russia
good. i am going to buy dji lens    Sony e mount bad autofocus
2023-9-9
DiddyDarnell
fansc207910d Posted at 2023-7-13 06:05
Thank you, this fixed the problem for me as well.
1-4 12:35
