Battery authentication failed
1468 8 2023-3-29
martin0598
Hi there,
I got a used Mavic 2 zoom. After turning on drone and remote control, the Dji GO 4 application says Authentifizierung der Batterie fehlgeschlagen (Authentication of battery failed). Battery was fully charged.
Application says, I got latest firmware. Can you please advice what to do?
Regards, Martin
2023-3-29
ArcticPhoto
Norway
Is this a genuine DJI battery?
Is it possible for you to try the battery on another Mavic 2 Pro or Zoom? A drone shop, or somebody you know with a Mavic.
Maybe the best option is to contact DJI support.
2023-3-29
martin0598
ArcticPhoto Posted at 3-29 11:33
yes, origin battery. No, don't know another Mavic Owner
2023-3-29
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. If you have a spare battery for your DJI Mavic 2 Zoom, kindly please try those to see if the issue persists. We recommend wiping the metal contact pins on the battery or the aircraft with isopropyl alcohol (concentration >75%). You may also provide us the serial number of the said battery via PM so we can check it here. Please keep us posted. Thank you.
2023-3-29
martin0598
DJI Paladin Posted at 3-29 16:53
Hi DJI Paladin,
sent you a personal message with ser num of batterie, can you please check?
Regards,
Martin
2023-4-1
DJI Paladin
martin0598 Posted at 4-1 03:24
Hi DJI Paladin,
Regards,
Thank you for keeping us posted, Martin. Kindly please check my response. Thank you.
2023-4-3
fans35ba6f62
Georgia
I had similar problem. It was fixed by slightly bending out battery contacts on the battery itself. Do nit touch terminals on Mavic side. Most probably, contacts on the battery went deformed or dirty.
2023-6-23
martin0598
I bought a new battery, now it works
2023-6-23
DJI Gamora
martin0598 Posted at 6-23 06:46
Hi, martin0598. Thank you for sharing the resolution. Glad that it is working now.
2023-6-23
