DJI Paladin
dronethemoment Posted at 4-10 07:27
Update: After having several issues with the DJI RC and Mini 3 Pro after this update and forum post, I finally got tired of it and plugged the RC into my macbook and used DJI Asstant 2 to force downgrade and then upgrade my firmware.
It appears I was affected by a "Zero Day" bug where the firmware was released with an issue and I immediately upgraded, and couldn't get the hotfix due to versioning of the software. The remote and the mini3 pro refused to refresh the update, so I had to downgrade on the computer.
Hi there. Sorry for the late response. We're glad that you managed to isolate the issue that you experienced. Regarding the "Flight Record Storage Limit Reached", this prompt is not an error message, it is a reminder that is mainly to remind you to upload the flight records. If you want to dismiss the prompt, after ensuring that the flight records are uploaded to the cloud, manually clear the flight record cache; or connect the DJI RC to Internet. If the flight records are successfully synchronized to the server, the prompt stops showing up. Hope this helps. Thank you for your valued support. |
