DJI Paladin
Hi there. Thank you for reaching out. If you are using the DJI RC (built-in screen) the use of the SD card will help you capture screenshots and screen recordings on the controller as Zooom stated in post #2. In addition, the DJI Mini 3 Pro battery LED lights will normally stay on when the battery is fully charged, if you are using the DJI RC, the LED will be turned off once fully charged. Should you have other inquiries, feel free to ask. Thank you for your valued support. |
