ay6810
Flight distance : 76631 ft
Singapore
Hi I had the similar problem when I used a micro SD card reader to read the files on a PC running Win 11. After formatting the micro SD card with the goggles command,, the micro SD in the drone still had the E:/ is not readable due to a different directory system or file format is corrupted. This happened for the goggles micro SD as well. In the goggles, the videos can be seen and played back. How do I rectify it? I have changed two cards, First sd card was Sandisk Extreme Pro 64 gb and the 2nd card is Kioxia 64gb.
Do I need to just connect a wire from Avata to the PC to download the files or can I continue to use a card reader?
