Farnk666
Flight distance : 1711394 ft
Yep, slave video feed is a problem.
It worked just fine earlier on, but DJI made a change in firmware that cut the number of channels and transmit power.
Seems like they were originally using frequencies that they didn't have rights to.
Set your bit rate down as far as it will go and manually select the channel with the lowest noise level. That helps for some people. |
