IPhone will not charge from controller
djiuser_o1slqh9iiHLd
Flight distance : 925791 ft
I have an Iphone 11 that I ise with my mavi air2.  When Im done flying, I notice my Iphone battery is really drained. So I checked it,by unplugging it from the controller and plugging it back in.  When I plug it in, it starts charging, then quits after about 2-3 seconds?  Has anybody else had this problem?  Is there a fix?
Thanks Rick
2023-5-1
Forget it I did not realize there was a charge switch in the software.   Thanks
2023-5-1
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Are you pertaining to the DJI Mavic Air 2? If yes, please make sure to enable the settings to charge the mobile device under the DJI Fly app > General Settings > Control Settings. If you still experience the same issue, please reinstall the DJI Fly app on your iOS mobile device and see if the issue persists. Please keep us posted. Thank you.
2023-5-1
