failed to load dynamic safety data
6042 10 2023-5-24
JustHope
Flight distance : 211814 ft
Sweden
Hey guys
Could someone help me on how to solve this problem: Failed to load dynamic safety data. Geo awareness function degraded.
The drone is updated, that is both the flysafe and the firmware, everything is caliberated and working as it should but still saying this!
Failed to load dynamicsafety
2023-5-24
SkyCryer
Flight distance : 1584596 ft
I had the same on first flight. Just connect to a hotspot like phone and update as written on the prompt. Then it should work, did. for me.
2023-5-24
JustHope
Sweden
Hello,
Thank you for the reply,  Unfortunately, its still doesnt work on my side. I have updated both and it keeps saying it is upto date  i.e. the Aircraft firmware and the Flysafe data are all up to date.
I even used a refresh to downgrade on my PC and reinstall the firmwares but to no avail.
Does it have any impact on the drone? if you know this? Problems?
2023-5-24
DJI Tony
Hi there. Thanks for reaching out, and we're sorry you're experiencing such an error. Can you confirm what DJI drone you're using? Thank you.
2023-5-24
JustHope
Sweden
DJI Tony Posted at 5-24 10:10
Hey Tony,
Thank you for the reply, it is a mavic 3 classic, I think i  have solved the problem now. I was able to update the flysafe after the satelite reached 30+. Maybe that was it or not but it stop showing up after the update.
2023-5-24
DJI Tony
JustHope Posted at 5-24 11:46
Hey Tony,
That's great news! We're glad you managed to resolve it. Please reach us back here should you have other concerns.
2023-5-27
djiuser_Lur1ztq29wLO
Flight distance : 1488999 ft
Hi There
I have the same issue.
Mavic 3 classic and 3 pro both working on RC controller show the same error: "failed to load dynamic safety data".
All software is updated.
Anyone can help?
2023-8-30
JustHope
Sweden
djiuser_Lur1ztq29wLO Posted at 8-30 04:57
Hi There
Hello,
I solved my problem by always updating the drones outside, where you will get satellite signal.
The dynamic data needs satellites to update and normally when you update in your house or in a confined space without some satellite signals it will only update the software but not the dynamic data.
I hope this helps.
2023-8-30
DJI Tony
Hi There
Hello there. If you are located in Europe, please check and ensure the Aircraft has a good GPS signal then refer to the following: Go to Camera View > Settings > About > FlySafe Data, and click Check for Updates, after updating, the latest version code will be displayed on DJI FlyThe latest version of the Aircraft Dynamic Safety Date should be 2022-11-03. Have a great day ahead.
2023-9-19
djiuser_ObQa6aOYmcVj
Flight distance : 2182 ft
Latvia
JustHope Posted at 2023-5-24 11:46
Hey Tony,
I have them same issue with avata 2 it keep saying me that googles dynamic safety database not updated. But all firmware is updated and i cant take that off the screen
4-26 11:56
djiuser_0mXhxQvGNQH1
djiuser_ObQa6aOYmcVj Posted at 4-26 11:56
I have the same issue with my avata 2
4-26 21:10
