DJI Paladin
Thank you for your response. First, the Panorama function was launched to resolve the smaller view of the existing camera. The principle of the Panorama function is to capture several photos with a certain overlap ratio and stitch them into a single photo for a wider view. Stitching is a process of searching for the edge parts on two images through an algorithm and overlapping the areas with the most proximate imaging effects to complete auto-stitching of the images. When the target is shot at a close distance, the coincidence degree between photos shot will become lower. As such, the software algorithm is unable to match the photo images, resulting in an error with the stitching position or a stitching error. If a panoramic photo is poor in quality after stitching, it is often due to two possible reasons. The first is an excessively low overlap ratio for the photos that were shot. The second is a substantial change in the capturing environment, leading to a significant exposure difference in each photo.
Here are some solutions for panoramic photos shot by drones:
1. Please avoid capturing when there is strong wind. When taking a panoramic shot, keep the aircraft still. Please try capturing in an environment that is not windy and check if the stitching is still abnormal.
2. Please stand as far away from the capturing target as possible. It is recommended to capture a target from 50 m away and then view the stitching effect.
3. Try capturing in an environment without wind after gimbal calibration and IMU calibration.
4. Try formatting the microSD card or using another microSD card. Before formatting the microSD card, please backup the data on it.
5. Try using a mobile device to capture.
6. Refresh the firmware and try capturing again. |
