DJI Paladin
djiuser_qVkMdNEZpBAq Posted at 3-5 02:49
hi.
it's not clear on how long the operating time of each device when its not plug on power or charging case.
An alos how can you use or plug the transmitter to the charging case to extend the operating time when you only have one charging case and you are using it to charge the receiver while in use. i mean you cant plug those 3 device at the same time on the charging case while they are all being used at the same time. its only possible for the receiver when its on a desk. not possible if mounted on a camera. the transmitter are not possible to charge when in use when its clip to a person during interview or speech or seminar when a person is on stage in front of crowd doing seminar. forum, training, etc.[view_image]
Hi there. Thank you for patiently waiting. The RX supports simultaneous charging and use, which is charging through the Type-C interface on the side of the fuselage. The Type-C port is also designed for charging. Please note that there is no time limit when using the unit when charging. Feel free to use the product with confidence. We appreciate your valued support. |
