Fines Aerial
Flight distance : 17269813 ft
Hi,
I was doing some test shots today with a client and Waypoints seemed to have some glitches.
I'm not sure of the max speed, but above about 8 mph the gimbal movements weren't smooth.
Here's an example:
https://we.tl/t-iUAYxso7dK
This was a simple 3 point waypoint mission. #1 has the gimbal at -90deg, #2 is about 500' to the right with the gimbal at 0deg. #3 is just further on with the gimbal at 0deg.
If you watch at about 3 sec there is clearly a "jump" in the gimbal movement that ruins the shot.
Is there a max speed that Waypoint Pro can interpolate gimbal movements? At a much slower speed like 3mph it worked, but that's not the shot the client wanted.
(As a feature idea it would be nice, as with other Waypoint programs such as Litchi or Dronelink, to be able to choose a Bezier or linear interpolation, and then manually shape that for the desired effect.)
