After updating everything, there is still no RID on my Air 2S. Neither can I see it in the sttings of the Fly app nor can I find a network on my mobile phone that starts with RID.
I can't see my Drone on Drone Scanner app (Using Latest Version) yet and I am using the latest version of Firmware of the AIR2S. I checked it using the Digital Assistant Software. I am also using the latest version of the DJI Fly app as well. In the software I made sure remote ID is turned on and working. I am using a iPhone 14 Pro max using the latest version of the IOS as well. So I don't know where else to go to make sure this works.
Shawgod Posted at 7-30 09:13
I didnot know you can turn it on or off. Where are this settings?
Mobilehomer Posted at 9-12 10:12
Dario, if your air space controlling agency does not require RID the 2S will not be broadcasting it. DJI uses GPS location to enable/disable it.
Interesting! I’m in Croatia (EU) and RID will be mandatory on January 01 2024. Did not know that it is location dependant.
I see people in the States with RID enabled. Is the RID already obligatory in USA?
Yes, my Air 2S and Mavic 3 Classic are both transmitting RID. Yours should be sometime soon as soon as DJI enables it for your location. I don't know if that requires an update. Try signing out and back into your Fly app. That may trigger it.
Mobilehomer Posted at 9-12 10:28
Tried that but it didn't help. Will have to wait till then. Anyway, thnx for your help
I still can't see my drone. I have tried everything to get it to work. Again I have tried Drone Scanner because that is what is available on the App Store and the drone is updated to the latest version. So I don't know what to do.
