My video & photo files are locked.
1087 3 2015-8-29
EL SID
I can view all my files ok,but if I go to make any changes I get a pop up that the file is locked and read only.
Is there a setting that I'm missing so that when I record my files will not be locked?
I can make a copy and work on that file,but I would like to be able to unlock my files.
FYI- I use a MacBook Air.
2015-8-29
Rigworker
Flight distance : 52303 ft
If you are using an adapter for the SD card, many have a little switch on the side that locks the files. Check that that switch is set to unlocked.
2015-8-29
EL SID
Rigworker Posted at 2015-8-29 16:54
If you are using an adapter for the SD card, many have a little switch on the side that locks the fi ...
That was it!
Problem solved. Thanks
2015-8-29
Rigworker
EL SID Posted at 2015-8-29 18:40
That was it!
No worries, here to help. Glad it wasn't something serious.
2015-8-29
